Question about Hotpoint WMA40 Front Load Washer
Where can I locate the pump on Hotpoint Aquarius extra WMA40 and how do I replace it?
    Problem Solver:
  • 6 Answers
Hello, the pump is located behing a small access plate which is at the bottom of the machine and held on by 4 self tapper screws. access can be made there then 2 screws hold the pump in place which you can get to by resting the machine on its face
Posted on Jul 23, 2010
Our Hotpoint Aquarious Extra WMA40 will not discharge water and when it goes through it's cycle the water builds up and the only way it comes out is through the front and soap tray
I would guess something is blocking the drain pump. Collar stays are enemies with drain pumps, couldn't tell you how often I run into that.
Apr 14, 2013 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius extra wma40 - door locked light is flashing and want lock. also before this happened a sound from the machine like an explosion which blew out fuse in the house. please advice
Hi.
I suspect that the top control board has blown , this happens when the brushes wear out in the motor, and short circuit the motor armature, which in turn blows the control board.
Either way it is likely to be an expensive repair, my advice to you would be to buy a new washer if it is more than 5 years old.
I know from experience that this is the most likely course.
Nov 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Extra WMA40 - Prewash light flashing and cycle not completing? The water level also looks to be very high? As tenants this machine has been installed (we suspect second hand) to replace a...
The water level on the Hotpoint WMA range of machine should be below the door, check out the error code definition at this site. You probably have a pressure chamber blockage or partial blockage. There are also workshop manuals for the Hotpoint WMA & WM machines which run through this sort of repair.
Mar 20, 2010 | Hotpoint WMA40 Front Load Washer
I had a problem with my washing machine model no. Hotpoint Aquarius WMA40. Washing is going but after full washing water is not going out pls help me
the sump under the machine needs to be cleaned out, most causes of this is the use of color catcher sheets getting caught in the sump.
email me at appliancesdav@hotmail.com
and i will talk you through to fixing it.
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The brushes are not located in the usual place at top of machine could you tell me how to locate them. We have an aquarius extra wma40
The motor is now located at the bottom rear of washer.
To access same, remove lower rear panel of washer.
You will see the motor.
Remove drive belt, and undo 2 bolts securing motor to drum.
Remove motor plug and earth wire, lever motor away from supports, and remove same. You will now be able to access the brushes.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint WMA40 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
HOW DO I REPLACE THE BELT TO AN AQUARIUS HOTPOINT WMA40
hello take the back off the washer at the bottom of the washer you should see the motor and where the belt goes. the motor sits on bracket with 2 nuts each side get flet tip pen and mark where the nuts sit get a spanner unloosen the nuts the motor should drop down get your new belt put it on the the large pully first and slide it round the motor and bolt the motor back in its place good luck
shaun
May 08, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius extra wma40 wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Apr 03, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
161 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
