Driver problem for sis acclerated graphics port incomplet or damaged (code 19). windows cannot load drivers for sis processor to AGP controller properties
  • 13,433 Answers
You need to install the drivers for the device.
sis drivers are at
http://www.sis.com/download/agreement.php?url=/download/
Posted on Apr 22, 2008
GRAPHICS CARD
http://uk.asus.com/Motherboards/Intel_Socket_775/P5S800VM/
I see it is the VM/S version, and not the Asus O.E.M. version above.
My thinking is the motherboard was made for a proprietary computer manufacturer.
Perhaps NEC or Packard Bell.
Using this line of reasoning, it is my contention that the graphics expansion slot is the same, and motherboard chipset; for the VM/S version, as well as the Asus OEM VM version.
Going further...............
Specifications:
Graphics Expansion slot -
AGP and 8X........AGP 8X
Motherboard Chipset:
SiS 661FX - Northbridge chip
SiS 964 - Southbridge chip
http://www.motherboards.org/mobot/chipsets_d/SiS/661FX+964/
So we know the motherboard will support an AGP 8X graphics card.
Another item you need to have knowledge of, is what is the Minimum power requirement; for the particular AGP 8X graphics card you are looking at......
Let's look at some examples,
(They are getting fewer, and fewer; as the graphics card technology has gone to PCI Express.
PCI Express has evolved to the PCI Express 3.0 technology now)
A) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
Scroll down to - Features
-> Minimum PSU Wattage requirement
(Ignore of you are aware;
PSU = Power Supply Unit
The Power Supply's used in personal computers are SMPS.
Switched-Mode Power Supply)
MINIMUM power wattage requirement for the above AGP 8X graphics card, is 250 Watts.
Something I would like to impart;
Back in the day Power Supply manufacturers 'fudged' the True, Actual maximum wattage rating.
Actual maximum wattage rating, was more like 60 to 70 percent of what was stated.
If we use a 250 Watt PSU from back in the day, as an example; actual maximum rated wattage would be 150 Watts, to 175 Watts.
[Simple equation(?);
250 divided by 10 = 25
25 times 6 = 150
25 times 7 = 175 ]
Point?
DO NOT under power a graphics card!
A) It will not work right, or at all.
B) It will burn;
The gold plated contact pins on the bottom of the graphics card.
The contact pins in the graphics expansion slot.
Takes a while usually, but when done you can use the motherboard for a Frisbee.
Here is a Power Supply Wattage Calculator,
http://extreme.outervision.com/psucalculatorlite.jsp
Takes about 2 seconds for the page to fully load.
Need guidance in using it post back in a Comment.
It is the 'Rule of Thumb', to have at least 10 percent more power, than what is required.
Easier on the Power Supply, as it doesn't have to strain to keep up.
I myself would recommend a 350 Watt power supply, at least.
One more thing if I may;
LOAD THE SOFTWARE FIRST!
Load all the software that comes with the graphics card.
It will be on the Installation disk that comes with it.
You will be loading the Drivers, and user interface.
For a graphics card utilizing the ATI (AMD) technology, you will be loading Drivers, and the Catalyst Control Center.
For a graphics card utilizing the Nvidia technology, you will be loading Drivers, and the Nvidia Control Panel.
AFTER doing so, THEN turn the computer off, FOLLOW Anti-Static Procedures, and Physically install the graphics card.
Why?
Because when a device is installed on a computer that has Windows on it, Windows will 'break it's neck', to find suitable, matching drivers.
If THE drivers are not already there, Windows will match up one of it's THOUSANDS of generic, one-size-fits-all drivers.
This = No
A Driver conflict can result........
Windows: "Which drivers do I use?
These or THESE?"
For additional questions please post in a Comment.
Or Reply, at the end of this solution.
Regards,
joecoolvette
1) SMPS;
http://en.wikipedia.org/wiki/Switched-mode_power_supply
2) AGP technology;
http://en.wikipedia.org/wiki/AGP
3) PCI Express technology;
http://en.wikipedia.org/wiki/PCI_Express
May 10, 2013 | ASUS P5S800-VM Motherboard
IBALL SIS AGP CONTROLLER
Hello try the SIS homepage here:
http://w3.sis.com/download/
Or here:
http://w3.sis.com/support/support_faqs_26.htm
You have to select the windows system you are using, and the graphic card model, to find the driver.
Good luck
Mar 16, 2013 | ASUS P4B533-VM Motherboard
K8S-La PCI sockets fail Windows 2K fails to detect - no I/O map or interupts
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00257657
What is a 56k Modem doing in that list? You using dial-up?
At any rate, download, and install the Chipset drivers.
Need guidance in downloading AND installing the Chipset,
(Motherboard Chipset) drivers?
I need the Product Number of the HP or Compaq computer.
This can be found on the back of the computer, in the white Service Tag. P/N = Product Number
Also need to know what Operating System you are using.
Windows 2000?
Post back in a Comment.
Regards,
joecoolvette
[Let's take a look at a Motherboard Diagram, that fits the technology of that Asus K8S-LA (Salmon) mobo,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU = Central Processing Unit. Another term used is Microprocessor, or simply - Processor - for short.
As you can see the Northbridge chip, of the motherboard chipset; handles the Faster capabilities of a computer.
Processor, Ram Memory, and HIGH-speed graphics.
HIGH-speed graphics is AGP, and PCI Express.
A graphics card inserted into a PCI slot; or using Integrated Graphics; is NOT high-speed graphics.
The Southbridge chip of the motherboard chipset, handles the Slower capabilities of a computer.
A) The PCI bus. (And Integrated Graphics)
B) IDE bus
C) SATA bus
D) USB bus
E) Ethernet bus
F) Audio (Sound)
The Northbridge chip of the motherboard chipset, is a SiS 760.
The Southbridge chip of the motherboard chipset, is a SiS 964.
http://www.motherboards.org/mobot/chipsets_d/SiS/760+964/
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
Driver: A small piece of software that allows the Operating System to communicate with a device
Device in question is the Southbridge chip.
Operating System is Win2K (?) ]
Jan 02, 2013 | ASUS (K8S-LA) Motherboard
I have an asus k42j series ..I need a display driver driver 64...please help
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
http://download.cnet.com/%7Bvalue=http://www.download.com/windows-7-professional/3000-18513_4-10906772.html Windows 7 is more than what Vista should have been, it's where Microsoft needed to go. How much damage Vista did and whether Windows 7 is enough for people to finally abandon Windows XP are questions that nobody has the answers to right now.
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html This package consists of SiS VGA Drivers, AGP Drivers, VGA Utilities, and Installation for Windows 7. Utilities include Control Center and SiStray. The Control Center provide some settings like gamma correction, video, TV output, driver mode, screen rotate, and product information. The SiStray provide Control Center entery and some settings like resolution, refresh rate,and rotation. The Installation are capable of installing/uninstalling drivers and utilities respectively.
Supported Chipsets:
SiS671, SiS672, SiS671FX, SiS672FX, SiSM671, SiSM671MX, SiSM672, SiSM672MX
http://download.cnet.com/%7Bvalue=http://www.download.com/msi-nvidia-based-graphics/3000-2108_4-10162298.html hope one of these helps
May 21, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My lenovo 3000c series also have this problem, code:19. please advise.... thank you
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged or corrupted.
Probably data in the registry for the device and its driver have been damaged/corrupted
Try these options,
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
or
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back or restore to the most recent successful registry configuration.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
I need driver help, yes i am a idiot
No your not.Go to microsoft web site or use the built in Windows Update on your computer.If you haven't downloaded the update tool it will ask you to install it.After it installs the update tool, run it.Pick the updates you need lnstall them some will require you to restart.Later check the automatic update feature to check for updates.Other updates will be from the manufacturer or your PC,check for their updates.Software from their sites.This is not hard.If I were you I would buy a general book on XP you can learn easy steps to keep your PC up to date and won't have to ask anyone (except FixYa.com) good luck
Sep 05, 2009 | Computers & Internet
Problem for my video card drivers
Go under your start menu and click on windows update, and when it pulls up internet explorer click on custom install and you'll see all the updates click on hardware and see if windows can install the driver.
Jun 17, 2009 | Ultra ATI Rage 128 Pro Graphic Card
DRIVER PROBLEMS
you have to install the chipset driver using your driver cd...
is this cleared your problem?
Feb 19, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
