Question about Garden
Hi! I bought plasma cuter i-CUT 40D HF from German ischweissen.de. I connect all cables and air hose with filter and set it to 4,5 bar. I turn switch on fun goes and its ready for cuting. When i press switch on torch and try to cuting air go out from torch and HF - ignition doesent work. Just air. Then i call a dealer and he send mee new cuter. With this cuter is the same problem. Now i have two cuters but no one works. Imean is stupid to call dealer again. I think problem is in HF- dont hear any sound. I try to change other torch and ground cable but dosent work. O.C light is off. Please help mee to resolwe this problem. I dont know what to do. Thanx
I have cheep chinese plasma cutter cut 50 comes on and does spark got air it will not cut what could be problem
HF spark gap adjustment needs to be done, it's inside the machine, front of bottom circuit board.
Dec 03, 2014 | Welding Tools
I have a accurate tools 3n1 stick,mig, and plasma cutter everything works except the plasma press the trigger air comes out but no arc at all on tip to metal can hear the relay clicking when switch between...
Could be as simple as having the ground cable connection placed into the wrong port on the front of the machine. Foot peddle/machine selection switch in peddle mode instead of machine mode? Internally it could be high frequency spark leakage or failed HF circuitry. These are the most common causes of spark failure. Oh and be sure you have good consumables and they are installed correctly. Air pressure leaving the torch head should be around 70 psi.
Aug 27, 2014 | Welding Tools
How to connect the compressor
Step 1:
Hi chuck305,
Have the compressor out of the box, with all cables and parts next to it.
Step 2:
Attach the Intake Air Filter to the top side of the air compressor.
Attach the Moisture tap to the belly of the air tank if not already attached.
Step 3:
Take the air hose and attach it to the output connector at the front of the Compressor.
Take the Air Gun/Attachment and plug it into the end of the air hose, making sure it locks securely.
Take the Power Cable and Plug it into the nearest safe wall socket, turn on the wall socket.
Step 4:
To start up the air compressor, toggle the On/Off Switch on the front of the Compressor, this might be in the form of a Red Push/Pull Button.
Step 5:
Best of luck setting up your Air Compressor,
Jacob Murphy
Dec 24, 2012 | True TBB-2G Commercial Refrigerator
Hi I just bought a husqvarna 55 and once it worms up, it doesn't want to run at full throttle, as if it is starving for gas. I haven't changed gas filters yet, but after that I don't know...
Basic stuff first, replace the fuel filter in the tank on the end of the fuel hose, clean the air filter, if fitted check the spark arrestor in the muffler is not blocked, check the fuel hose for splits or leaks, check the rubber induction tube between the cylinder and the carb for splits.
Jun 01, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Washer starts within 2 minites hf error occures pressing pause/cancel and then pressing starts and finishes normally
'hf' normally means there is a problem with the water inlet(s).
If you have checked that the hot water tap is turned on fully and the hose is not kinked or squashed at the back, it is worth while checking the hot water inlet filter. Turn the tap off and remove the hot water hose at the washer end. Inside the inlet port there is normally a little filter which should just slide out. Clean if necessary and replace it and the hose. If after turning the tap back on there is no improvement, carry out the same with the cold water system. If there is still no improvement the problem is symptomatic of a malfunctioning water control valve. Sorry but it needs a service call ;-0(
If this has assisted you or clarified the situation please consider a 4 thumbs up on our rating
Thanks and good luck!
John C
Apr 13, 2011 | Kenmore Washing Machines
I have a plasma cutter mode 40D. when I first got it about a yr. ago I tried it and it seemed fine. Went to use it on the weekend. Hooked up my air compressor to it and everything else hooked up and can ...
The fan you hear is the cooling fan for inverter.
The air pressure is delivered by the air compressor, through the air filter/regulator device.
Check what is the pressure of the compressor, and the regulated pressure on your pressure gauge (if you have in the front, or may be in the rear of your cutter).
Jun 21, 2010 | A & A Manufacturing Ramsond 40D Plasma...
I cannot get a good edge when cutting its very serated, and when it arcs I can only cut for a very short time befor it stops cutting. I am cutting steel 1.6 mm thick using 4 bars of air and around 80 amps...
ensure you have a good ground connection.
try setting your machine to a lower setting for sheet metal.
approx. 25 amps, and about 2 to 2.5 bar
finally movement is everything, smooth and steady.
settings vary from machine to machine, good luck
Oct 05, 2009 | Inverter Welding Tools
No Arc on a Cut 40 Plasma cutter
Check your consumbales to be sure they are tight in the torch head. Check your ground be sure it's good and connected to the pc you are cutting. Make sure you are running air at 65 to 70 psi as it exits the torch. Email me if you have any other questions.
Jul 14, 2009 | A & A Manufacturing Ramsond 40D Plasma...
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Oct 21, 2007 | Kenmore 44832 Front Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
