Question about Frigidaire FAX050S7A Air Conditioner
My Frigidaire FAX050S7A window mount a/c unit recently stopped blowing cold air. The fan works fine and i can even hear the compressor turn on when i switch from fan to a/c. do these need recharged?
  • Frigidaire Master
  • 43,501 Answers
Yes they can leak and will need a recharge....just check first that the leak is very small or can be fixed before spending the money to recharge it...with the low cost of window A/C units you can easily get a repair bill for more then a new one would cost...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Frigidaire A/C window unit not cooling. I hear a switch cycling but I am not sure the compressor is working. No coils are cold. Fan works.
The switch cycling is probably the contactor-ley that with the help of the capactor will close the contacts and provide power to the compressor.
But finding the diagrams/schematics for a window air conditioner is hard so I hope you kept yours.
A general note, normally if the compressor is gone in a window unit, it is normally cheaper to replace than to repair.
Jul 22, 2011 | Frigidaire Heating & Cooling
Does it make sense that a frigidaire plhs67egsb3 refrigerator freezer could stop working simply from overloading? The compressor is running, the condenser coil was clean but the evaporator coil was frozen...
the defrost heater or thermostat circuitry is bad,you need to test both components,also the defrost timer control if the other parts test o.k..,the defrost tstat has to be below 32 degrees or it will test bad/open,when the evaporator coil gets iced up you cannot blow cold air through a solid block of ice,(NO air flow)means no cold air throughout the unit even with the evaporator fan running
Apr 12, 2011 | Frigidaire Freezer FFU1212D
The Refrigerator does not get cool but freezer works fine
Make sure that you are not overloading the top shelf of the refrigerator section. There is a small vent near the top where cold air blows in. You should also be able to hear a fan blowing as well when the compressor is running. The fan will be easier to hear when the freezer door is open. If you can't hear the fan, likely the motor has gone out and the cold air is not circulating like it needs to be.
Oct 02, 2009 | Frigidaire Refrigerators
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Frigidaire FAX050S7A Air Conditioner Logo
464 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
