Question about B&K Precision B+K Precision B&K Precision Triple Output DC Power Supply (BK1651A) Power Supply
B-k precision 1760 A - adjustable out voltageo volt CH-1 CH-2 no out voltage schematic diagram
Tip
Cyberhome CH dvd-300
Power supply problems. There are many reports on this site for problems related to the cyberhome dvd player, one of them mine. Here is what I found. The dvd drive was ok it was the power supply that failed after a power surge. The power supply is a flyback power supply using the viper22 switcher by STM Microelectronics. you can download the specs with a schematic diagram simular to the one in the cyberhome unit. I wound up replacing the shunt regulator (TL431) Optical coupler (PS2561-a-1) , the 2200uf cap and the 1000 uf cap. this brought the 5 volt output to 5 volts which was the problem. The parts can be ordered from Mouser Electronics.
1000uf @ 10 volts PN UHE1A102MPD
2200uf @ 25 volts PN UFW1E222MHD
TL431 PN 512-431CLP
PS2561 PN 551-PS2561-1-A
Warning: The high voltage side of this power supply has 120 VAC and 161 volts dc when energized. thak precautions when measuring the voltages on the output. Good luck
on Oct 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Wiring diagram for a reset button on a razor e-100 scooter
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Nov 10, 2012 | kawasaki Quad Bikes
Lambda ews600-18 voltage goes down.
there is a short circuit protection and overoad protection to smps so o/p capacitor may short or secondary diode may short .so check voltage at primary when switched off after 33seconds whether switching process is going or not for that check dc volt at i/p capacitor then check volt at collector of transistor if metr shows 1digit then switching is going if not then meter shows full dc volt check component near about that
Apr 13, 2010 | Lambda 40-Watt Power Supply
Mintek 1760 adaptor
check the input voltage and check to see if radio shack has a universil adapter to fitit! they should have somthing compable...most lickly its 12 volts
Nov 19, 2008 | Mintek MDP-1760 Portable DVD Player
Busted component
Getting a schematic is rather doubtful. You might be able to get a general idea of the circuit from somewhere on the 'net.
Was the power supply dead?
ATX style power supplies have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard.
If the component failure is in this section, this standby voltage will be missing or incorrect, and the computer will be dead- won't power on at all.
I've seen a number of catastrophic failures in this standby circuit, and repair isn't suggested or economically feasible, especially as some parts often poof beyond identification.
When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Jul 07, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Computers & Internet Logo
78 people viewed this question
Top B&K Precision Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a B&K Precision Computer and Internet Expert? Answer questions, earn points and help others
