No wirless connection icon
My laptop used to connect wireless but something went wrong and has been rebooted. i do not have a wireless connection icon. How do I connect wireless
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
This could be complex, but the simplest solution might be to do a system restore back to a date when you knew the computer was working properly. Try that, and let me know if that fixed the problem.
Posted on Apr 22, 2008
How do you get wirless wifi connection i need help
Good day. In regards to your problem you can do this steps but make sure that your computer or laptop should have a wireless card or wireless enable
For desktop computer you can check it by doing this steps:
> click "Start"
> Go to Control Panel
> go to Device Manager
> click Network Adapter then you'll something that says wireless adapter if there is one installed in your pc
For laptop usually all of them have built in wireless
> you'll be able to see a wireless icon on the lower right corner of your screen.
> there is also a light for your wireless connection
> you need to make sure as well that the wireless switch in your laptop is on so that you can connect to a wireless net work
For you to connect:
> you can right click the icon for wireless ( once you hover the mouse on the icon it will say wireless so that you'll know that you're clicking the right icon) on the lower right corner of your screen
> after you right click it will give you an option to connect to a wireless network
> just click the name of the connection you want to connect to
Note: if you have your own wireless choose that name from the list
> some wireless requires a security code to connect: make sure that you know the password for that ( usually it will says secured )
> if it says not secured then just click the name of the wireless and it will automatically connect.
Hope this help you a bit. Have a great day and thanks for using Fixya.
May 22, 2011 | Computers & Internet
I can not connect to my wirless local net work on my acer laptop what can I do to fix the problem? ( I was have a problem with avg free and it wasnt allowing anything to work on IE8 so i unistalled avg...
This should be a simple fix, do the following below.
1) Go to start, run, cmd, OK
2) After Cmd opens type this:-
netsh winsock reset catalog
--press enter
3) and again after pressing enter
netsh intip reset reset.log
4) Reboot
You should now be able to access the internet and your router etc.
After doing this go through and set up a new network, WiFi connection, using the icon, in the system toolbar, bottom right, click on the ICON, Right click, and select "Connect to wireless network" Select your network, if asked supply the WEP/WAP Key, password, and login, now you should be able to access the internet, through the router.
Also on laptop, in fact ALL "Clients" ie: Anyone who connects to the router. MUST have a Computer Name, a Windows login password, have sharing enabled, They also must have DHCP & Zero Configuration disabled in services. go, START>>RUN>>services.msc (enter), when the services window comes up, scroll down to DHCP, and turn OFF, set to Disabled, on start up, then, scroll down to Zero Configuration,and stop that and disable from starting too. Now reboot.
Apr 15, 2010 | Acer Aspire 3680 Laptop
Wirless router problam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
OR
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Nov 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless connection has dissapeared
If there is a wireless icon on the Task Bar then right click on the icon and then click on Repair (this will get the wireless router to issue your computer with a new IP address)
If you don't have a Icon on the Task Bar then go to the Control Panel - Network Connection and right click on the Wireless connection and then Repair.
If this doesn't work, take a note of the error messages and give me the details, then I can give further instructions.
Apr 05, 2009 | Compaq Presario Notebook
Wireless not working
Go to control panel click on system, navigate to hardware then to device manager than click on network adapters than right click on ( wireless network connection) and uninstall it, than restart computer and it will find new hardware. Click on new hardware icon and open available wireless networks and select network than connect.
Jan 25, 2009 | HP Compaq Presario V6000T Notebook
I need to turn my wirless internetnet option on and cant for my IBM thinkpad thanks
mostly the button is found on the left float side of your laptop 'IBM'. with two icons of a computer. please make sure that the button is on the side of the icon that shows a computer with weaves. so that your able to check the wireless access points you have in your range.
Wireless Connection:
Start > Control Panel > network connection>
Show network connections. If there is an X on wireless connection then connection is disabling and if no X then connection is enable.
make sure its enabled.
Right click on wireless network connection and click view available wireless networks.
You should see a list of available wireless networks
Then select the wireless network that you need to work on and click connect.
An icon in the lower right hand corner of your laptop should eventually appear stating that you are connected.
Then this will show you your wireless connection.
Excellent you connect to your wireless network.
Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
Wireless laptop failure
to look for wireless icon on windows XP start by clicking
start-->Settings-->Network Connections
here you shoud able to see wireless network connection
Double click on wirless network connection and below you
would see "show icon in...." and also " notify me...". Check
on this 2 box and click apply.Next time you'll be able to see this icon again.
goodluck,takecare.
May 22, 2008 | Computers & Internet
Wireless internet is not working my wirless card does not work
remove network connection for wirless,
remove wireless card,
reboot,
then shut it back down,
while off reinstall wireless card then boot back up,
it should ask you to configure it.
May 02, 2008 | Computers & Internet
My laptop cant find the connection
reboot the laptop make sure the w/l connection is enables>and right click on teh w/l i-con u can see on teh left side bottom corner on the laptop and select view avaliable networks(SSID) click on ur network and connect>and click on prefered net works and click on the network (SSID)>AND CLICK ON CONNECT RATE ME SOLVED IF ITS HELP FULL THX
Oct 30, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
212 people viewed this question
David Payne
David Payne
