Question about Apple iTunes
When I try to play a track from my library it says original file cannot be found and asks if I want to locate it? (This is on vista)
    Brigadier General:
  • 10,406 Answers
Your iTunes library is just an "index" to the music on your computer -- it does not always contain a copy of your music.
So, at some date in the past, you "imported" that track into your iTunes library. But, you all you did was create a "pointer" to the location of the "source" file.
Since you have deleted that "source" file, or have "moved" it,
the "pointer" has become invalid.
Say 'YES' if you moved the track.
Say 'NO' if you deleted the track.
Posted on Jul 21, 2010
I have a Nokia E63 . When files are received through bluetooth and when I give "Save" option, it displays "General : System error" , but somehow the files get saved and When I change...
Please refresh you music library from Music menu then in option you will find refresh you music library.
Then you will be able to play the song.
Mar 14, 2011 | Nokia E63 Cell Phone
Sony Network Walkman NW-E005
i don't think it is a copyright thing it should be file format comparability issue.
Jul 24, 2008 | Sony Network Walkman NW-E005 MP3 Player
Tip
Moving the iTunes Music Files to a Different Hard Disk/Folder If you are low on...
If you are low on disk space in your iTunes folder then you can move these music files to another hard drive and keep your music library in tact without the need to create your music library again.
If you want to transfer your iTunes to an external USB hard drive, make sure that it is powered up and connected to your computer before opening iTunes.
Opened iTunes, click Edit and then Preferences. Click the Advanced tab.
Make sure the Keep iTunes Media folder organized checkbox is checked, and click Change.
Then select the location where you would like to move your files to. Click Select the Hard Drive and Folder or OK once you’re done.
The files will not move into their new positions by themselves –To do this – click File, Library and Organize Library. Check Consolidate Files.
When this process has been completed, go to the new location of your iTunes media and check the music files to see if they have migrated across correctly. Also play one or more tunes to test the music files.
The redundant iTunes music files can now be deleted from the original iTune location (C:\Documents and Settings\…..…\My Documents\My Music\iTunes). Delete everything from iTunes there except files titled iTunes Library.itl and iTunes Music Library.xml. These are still needed.
on Jun 05, 2010 | Computers & Internet
Tip
How to transfer windows media player muisc to iTunes
You may have some music on Windows Media Player, and you want to add them into iTunes library for your new iPod or iPhone. Or you may want to move your iTunes bought music to Windows Media Player for portable devices such as Zen, Zune, Phone, Sansa, Archos, MP3/MP4 Player, etc. It’s easy to do that. And this guide will show the steps to do the job.
Part1. Transfer Windows Media Player music to iTunes
Step1. Open iTunes and select the File -- Add Folder to Library menu.
Step2. Browse to your Windows Media Player music folder. iTunes will ask you where your songs are located, which by default will be in your My Music folder on Windows XP, or in your Music folder on Vista.
Step3. Convert Windows Media Player songs to AAC format (.m4a). If you have files in WMA format, you will be prompted to convert those WMA files to AAC. This is a necessary step if you want those tracks available to play on your iPod or iPhone. If you have a large music library in WMA format, converting WMA to AAC may take a long time. Plan to do this at a time when you can leave your computer on and walk away to do something else for awhile. You can also import your WMA files as MP3 instead, which also allows them to work with your iPod, but makes them more portable if you buy something else in the future.
iTunes doesn't modify your original music files from Windows Media Player. It leaves those songs in their original location and makes copies in your iTunes music folder.
Part2. Transfer iTunes music to Windows Media Player
Because iTunes music has DRM protection, you can't easily import the music into Windows Media Player by drag and drop. There are two ways to transfer protected music from iTunes to Windows Media Player.
Method1. You can use iTunes to burn the music to a blank CD at first, then use Windows Media Player to rip the music CD, the DRM protection will be remove during the ripping process, then you can rip the CD into WMP library. This way is good for tranferring a few music. For large mount of music, it would take a really long time to transfer music.
Method2. If you don't have blank CD disk or you have many iTunes music need to transferred to windows media player. You can use DRM Media Converter. It can legally convert the protected iTunes music to non-protected MP3 music, then you can easily drag and drop the MP3 music into Windows Media Player.
Step1. Download and install the DRM Media Converter , the file size is about 7 MB. I have scaned it with Norton Virus protector and AVG spayware protector, it's safe without any warning.
Step2. Run the DRM Media Converter, Click Add to import iTunes music, which by default will be in My Music\iTunes\iTunes Music .Or you can run iTunes, click Edit -- Advanced Tab, there you will see where your iTunes media folder location.
Step3. Set the output audio format as "MP3 - MPEG Layer-3 Audio (*.mp3)"
Step4. Click Start to run the conversion, it will take a little bit time to finish the job, then click Browse to located your converted mp3 files, drag them into Windows Media Player, done.
on Feb 05, 2010 | Computers & Internet
Tried to download 50 albums to i tunes library,mp3
yes, try ripping the cd or dvd by placing in tray........open itunes and rip the track (s) you want...(itunes will convert the mp3 to mp4)....once all your track you want are done.......take the music file from the top of left hand side (make sure ipod is connected for this) and click hold and drag down to the ipod music folder (this will take a while depending on large the folder is) once you are finish never ever just unplug it you will lose your files EJECT from itunes............
May 14, 2010 | Apple iPod classic MP3 Player
Tried to download 50 albums to i tunes library,mp3 files, from dvd by drag and drop. all showing on playlist and also showing all tracks from each album. however none will download to my i pod classic and...
You really should NOT try the "drag and drop" from a DVD - it'll end up making symbolic links ("aliases") to each of the files rather than copying them into the iTunes library. If you click on them in iTunes on your computer WHILE the DVD is mounted they'll probably play, since it can "find" the original files. But your iPod can't "play" them from your DVD, can it? So either COPY all the MP3 files onto your hard drive from the DVD and THEN drag them onto the iTunes "Music" library icon or, instead, in the File menu, select "Add to Library" and select them from there. Oh, and first delete all those dead links with the little grey "x" or question mark by the name in your iTunes music main window to make it easier to tell the new "good" ones you add afterwards (do this with DVD removed).
Mar 25, 2010 | Apple iPod classic MP3 Player
Music in file manager instead of music library
once you load the music to the phone, restart the phone than go to library and see if it says searching device or similar and it should load all of the songs in your phones memory.
May 13, 2009 | Nokia 5800 XpressMusic Smartphone
Mosmp036 problems
Follow the following steps:-
1. Create folders on your computer for the various types of music you wish to keep and put all your MP3 files into these folders.
2. Connect your MOSMPO36 to your computer USB. I find it connects more reliably if I also connect the charger to the player at the same time.
3. I am running on WIN2000 PRO but I assume that Vista has Windows Explorer or its equivalent. Go to this and create folders with the same names as in 1. above in the Removable Disk folder which is your player.
4. Copy your MP3 files from the folders on your computer to the folders of the same name on your player.
5. Open MOS Jukebox which I assume you have loaded into your computer. If you have not you must do so.
6. Click on Sync. When it has finished building the music library:-
7 Click file, click exit.
I do not bother with play lists so can not help you on those. I always play back from "Track" which puts all your MP3 tracks in alphabetical order irrespective of which folder they are in.
Do not try to store all your MP3 files/tracks on one folder. The
MOSMPO36 does not appear to like folders of more than about 2 Gigabytes.
Hope above is helpful.
Mar 12, 2008 | Ministry Of Sound MOSMP036 MP3 Player
Error message when I try to play a cd,dvd or rip
Before we try blaming a faulty cd/dvd unit lets check out faulty Windows Media Player Software. Is Media Player up to date? Try installing iTunes set as default. That will force the cd/dvd association to iTunes. See if the player works or what the error is...If it works...Then re-open Media player make it the default again and see it what it does. or This is from the Microsoft site: Windows Media Player cannot find the file. This error message usually indicates the link from an item in Media Library to its associated digital media file is broken. Items in Media Library are links to digital media files that are stored on your computer, a network drive, a removable storage card, an Internet server, or another location. Links can be broken for one of the following reasons: * A link to a temporary file from the Internet cache (for example, a file from the Temporary Internet Files folder) was added to Media Library and that file was later deleted. * A link to a digital media file was added to Media Library and the file was later deleted. To repair a link Do one of the following: * If you deleted or moved the file, replace it to its original location. * If you moved the file, right-click the item in Media Library, click Error Details, and then enter the new location of the file. To delete a link Do one of the following: * Right-click the item in Media Library, click Error Details, and then select the Remove file from Media Library check box. * Right-click the item in Media Library, and then click Delete from Library. Good Luck, Tim
Feb 04, 2007 | HP Pavilion zv5034US Notebook
Apple iTunes Logo
70 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
