Question about Toshiba Televison & Video
Toshiba TV 32ZT29B. Picture intermittent failure. After working for 5 minutes from cold the picture fails for 1 to 2 secs every few minutes always returning to good quaulity picture. Problem repeats continually.
Posted on Sep 09, 2008
Picture disapears after few minutes
I think the electronics inside it have failed. My guess is that because its the picture only, it will fail in the same way if you play dvd into it for the same amount of time. The failure happens after it has warmed up, if you take it out into the cold you may get 1 minute more before it fails.
It needs replacing, its not cost effective to repair something like this, the failed parts may have partially damaged other parts in the unit so they could fail after a repair.
Dec 19, 2013 | Televison & Video
Does Samsung tcon board fit Toshiba TV?
maybe we are smart enough to know better than to be inpolite.
Dec 05, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
My 47LG50 is just over 2 years old, about 30 days ago I started to lose the video/picture At first it happeded every once in a while, now it is every 5-8 minutes. I can turn it off and turn back on and it...
This problems it could be those 2 long LCD inverter boards are dead,so it is not giving ur tv LCD screen panel the backlight to produce a picture or the tv Tuner signal board itself is the problems it dead.That the board,that take in the incomming broadcasting signal wire ur case the HDMI or Component cables.Take out the incomming broadcasting signal to the tv,turn on the tv,now tv have no picture,it should have a loud white static picture noises for good more 5-8 mins,than problems it not the tv Tuner signal board.Than it is those 2 long LCD inverter boards are dead.Tries websites like, to buy refurbishes 2 long inverter boards or the tv Tuner signal board for the replacement.
Mar 25, 2011 | LG 47LG50 47 in. LCD HDTV
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
KDS-60A2020 picture is intermittent. every minute
This sounds like a power board problem. It is likely that capacitors on the board are failing so they can only store enough charge to properly supply DC current to the video board for a brief time. A shop will most likely suggest that you replace the power supply board entirely. If it were my TV I would remove the board and replace the bad capacitors for a few dollars myself. Depending on your experience with electronics and soldering you may want to do the same. Otherwise having a shop replace the board makes the most sense - the labor charges to repair the old one would not be worth it.
Dec 05, 2009 | Sony KDS-60A2000 60" HDTV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
Picture loss!
It sounds like cold solder joints on the vertical IC chip. Not a major deal. The entire board should be looked over for other joints becoming cold.
Mar 12, 2008 | Toshiba 35AF44 35" Rear Projection...
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
Televison & Video Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
