Question about Tomtom ONE GPS Receiver
Loses map disply
My tom tom one loses map display after a short while, the display screen goes haywire but it still speaks the route.
  • lawrencelaw5 Jul 22, 2010
    My tom tom one loses map display after a short while, the display screen goes haywire and displays the keyboard or the favourites screen or a series of the letter q and asks if i want to replace it as favourite.
  • Tomtom Master
  • 7,993 Answers
You might have configured it to save battery. One battery saving feature involves turning off screen between instructions and another always turns off screen. See Screen capture from the manual (Go 730)
Posted on Jul 22, 2010
  • k24674 Jul 23, 2010
    I tried to give a simple answer to ONE simple question. But it appears that questions are aplenty and problems arise randomly. You can try to reset it. There is a button marked RESET at the bottom of the unit. You will have to use a straightened paper clip to press.
    Here is the link to the Tomtom ONE (which specific number) manual.
  • jo-ann123 Sep 27, 2010
    I have the exact same problem. I get random letters especially 'L' on my TomTom GO- 730
    I have tried reseting it both manually and also using the factory reset found in preferences.
    Also following instructions from the Tom-Tom site, I tried to clear the Flash files and also restored bad sectors, BUT I still get the same display issues.
    If someone knows why this keeps happening, could you please advise?
I PURCHASED A 335TM XL TOMTOM GPS AND AFTER FOLLOWING INSTRUCTIONS ON THE VOUCHER, MY TOMTOM SCREEN, DISPLAYS " NO MAPS FOUND.
You have to first load maps on the gps before you can use it. You go to tom tom website, then you update your tom tom with maps, then register your device. After doing that, I assure you will be able to use the gps.
Dec 26, 2010 | GPS
How do I get my GPS upgrade to in clude the new routes
unless you update maps on a regular basis (once a year or) new roads may not show on screen, the Map updates are not free,Garmin charges about $100 USD, the other issue is that not all the roads in the USA are in the software, so this can happen, the system is not perfect but it is good, just wanted you to knopw that Nextar doesn't have any updates, other do like Garmin and Tomtom.
Feb 08, 2010 | Nextar X3-08 Car GPS Receiver
I bought it in Australia, when i got back home (UK) i went to windows explorer and deleted the Australia map and replaced it with Great Britain map from a disc i had. When i turned on the device it says...
It is possible (almost certain) that the GB map you have is licensed to be used on that particular model. It is like Apple not allowing an Ipod owner to play music not downloaded through iTunes. You should consider buying a new GB, or even a European map valid for your GPS.
Jan 03, 2010 | Tomtom One IQ Routes GPS Receiver
The screen on my Tom Tom One fades and then goes blank the voice still is on, how do I get to battery settings? Someone told me that it might be battery savings setting
Try touching the screen instead of the power button
If that brings up the display try the procedure below.
It can usually be fixed and tends to be just an option in the preferences menu
Touch a regular map display once
Now touch the Safety Preferences once
Press Done until you see the Turn Off Map Display
Select NEVER
Select DONE
Select DONE one last time to return to the map.
You didn't say how old it was and if it has a lot of use and is coming up to 2 years old it may need the battery replacing.
Sep 16, 2009 | Tomtom ONE GPS Receiver
If my street goes directly to main street but my map sends me the long way to that main stree, how do I correct it.
i don't think you can. just go the way you normally go and the tom tom will recalculate the route and you shall be on your way.
Sep 05, 2009 | Tomtom One XL GPS Receiver
Tom Tom 720 keeps jumping to main menu
Well I finally figured it out for those who might run across this problem.
It seems that when it got hot and expanded the grey bezel around the screen would touch the screen just enough to activate it. I gently pried the bezel up just a bit and it seems to have solved the problem.
From Ban One
Jul 25, 2008 | Tomtom GO 720 GPS Receiver
Startup screens
How to contact Support
icon_register.gif Need information on how to use this site? Or how you can contact us? Follow the link below or call
Mar 08, 2008 | Tomtom ONE GPS Receiver
Tom Tom ONE Version 3
Radioland,
I am having the same problem only I am trying to with mine only I am trying to update my guarenteed map. I have DSL and usually have no problem but it is taking over 3 hours to even attempt the download then I get a system error.
Nov 23, 2007 | Tomtom ONE GPS Receiver
Fix a tomtom
Turn the tomtom on, and then press the reset button on the bottom of the unit with a paperclip. After the reset turn off the unit and then turn it back on. Make sure you have not dislodged the sd card from the unit.
Mar 19, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
216 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
