Question about Cell Phones
My touchscreen was working fine up until today. i guess i slept on it and something happened where i cant use the touch screen. Now its locked and i cant tap it to unlock my phone. I have the tmobile wing
In my years of having touch screen phones: they never end well.
they are very easy to break or mess up the touch screen. and once this has happened....you need a new one.
turn a claim in to your phone service. maybe insurance will get you new one. be careful!
Posted on Jul 21, 2010
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Wont slide unlock
probably the touchscreen just broke on the bottom part after a while
Jun 26, 2013 | Apple iPhone 3G
I have a samsung memoir, and i was using it all night and it worked perfectly fine, but today during school, when i was seleting to go to my texts messaging it went to another thing, like i click something...
calibrate your touch screen. pull out battery and put back in, if anything the touch screen s porbably bent from pressure, puttting it in your back pocket could cause this. if calibrating it doesnt work, you need a new touchscreen or a new phone
Feb 28, 2011 | Samsung Memoir SGH-T929 Cell Phone
I purchased a 3M 15"
This display uses a capacitive touchscreen. It relies on the conductivity of your finder work. It may be that it has lost sensitivity and only works when there is a path to ground through your body. If this is the case then the touchscreen will need replacing.
Feb 18, 2011 | 3M 11-4922-129-00 (Black) 15 in. Flat...
Touch screen doen't work
If there is a PIN assigned and the PIN can't be entered in because the touchscreen isn't working, then the PC will not recognize it. The communication routines between the Nuvi and PC will only happen after the PIN has been entered. If your at home, you will get to the main menu because that's your safe location where it will not ask for a PIN. The touchscreen is bad and needs to be replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jul 26, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 760 powers on but the touchscreen will not work
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
May 10, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
The touchscreen of my Z22 is broken
The Z22 is a bullet-proof device for securely saving your personal data, and full marks go to the team at PALM for its solid design. However, the AGE of the Z22, over the last decade, results in 3 problems - the batteries are all dying, and the delicate plastic touchscreen top layer is deteriorating - simply through AGE. When you say the touchscreen is "Broken", I would guess you mean that it does not respond to touch commands from the black plastic stylus that sits in the slot on the back, side, of the unit, when stored. I have never actually seen or heard of a screen that is physically "broken" - like the thousands of iPod, iPhone, Motorola RAZOR, and other touch screen phones that you see today, with cracks running across the broken GLASS. It "Could" happen that the glass screen under the top plastic touch layer is, actually "BROKEN", with the resulting cracks, but this is unlikely, since the trim around the screen is raised a HUGE distance, compared to today's touchscreens.
You can easily replace the screen for $9 if you wait for free shipping from CHINA, or, you can try a few tricks I learned on my Z22 over the years. I have put it in the freezer - which worked temporarily, heated it with a hair dryer - which worked temporarily, and peeled the top plastic layer off the screen- which worked temporarily. I have also replaced the screen with a new one. It is IMPERATIVE to put a hard plastic cover on the Z22 at all times- or you will eventually loose the screen again...
My Z22 page is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I hope this helps you to get your Z22 back up and running
have fun
good luck
robin dusty graves
Z22 PALM PILOT touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg
Dec 12, 2009 | Palm Z22 Handheld
Leapfrog Leapster touch screen
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Apr 10, 2009 | LeapFrog Leapster 2 Learning System
Htc touch, touch screen not working
The touchscreen is a thinlike mylar sheet that overlays the screen. Once damaged, all you can do it get it replaced. To verify if the touchscreen is "smashed", try using the thumbwheel or up and down buttons. If you can move around the display, then this means the touchscreen is damaged but will not prevent you from using your device, that is, until you turn it in for repair/replacement.
Mar 20, 2009 | HTC Touch P3450 Smartphone
Mx-3000 just froze up
This happened to me today. I plugged the programming cable into the MX 3000 and the screen became "un-froze."
Jan 08, 2008 | Universal Remote Control MX-3000 LCD...
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
