Question about Fujitsu fi-4120C Path-Through Scanner
Scanner grabs multiple pages at once
Brand figitsu fi5120C.
  • 81 Answers
SOURCE: Multiple sheets
You can try to clean the retard pad under the feed roll, but for best results you should replace it. Parts are readily available on the web. You should spend around $20 for the pad, and $50 for the feed roll. You may not need the roll. Examine it and see how the tread looks. These parts are easy to replace.
Posted on Feb 29, 2008
Binary Bob
  • 91 Answers
SOURCE: Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Posted on Dec 10, 2008
  • 14 Answers
SOURCE: Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Posted on Mar 03, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
Posted on Mar 04, 2009
mohanchennai
  • 490 Answers
SOURCE: scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Posted on Jun 13, 2009
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Scan multiple pages
Yes, it is possible, if your scanning application has batch scanning option. However, pls provide the scanner model and scanning application details to provide the exact soltution.
regards,
Tech Satya
Feb 09, 2010 | HP Office Equipment & Supplies
Cannonc DR4010 c pulls thru all the pages at one time- it does not pull individually-
This is clear roller problem. Clean the rollers thoroughly witha damp cloth. The ****** rollers should ideally be cleaned in power-off mode. This should solve paper feeding problems. Check if the pages are dusty.
The rollers last for about 250,000 scans. If it has crossed this number, you need to change them.
S. Mohan, Chennai, India
Jul 20, 2009 | Canon Office Equipment & Supplies
Scanner is not picking the paper
It is likely that your paper is the problem. Get some new or different paper and try again.
Jun 18, 2009 | Fujitsu fi-5120C
Scanner is not reading multiple pages...
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Mar 03, 2009 | Canon DR-5020 Path-Through Scanner
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
I'm using a CanoScan LiDE 60 and I have no idea even how to begin. I need to scan in 5 different documents with numerous pages and I was hoping to create a pdf for each. Can you help me get started?
Use the CanoScan Toolbox that shipped with the scanner. If you don't have it, then download it from the Canon Website. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
If you don't have the scanner driver, then download that too.
Once you have Toolbox installed and you open it, there will be a PDF button. The scan to PDF window will open. If you're planning to do a multiple page pdf, then click the dropdown menu next to 'Save as Type:' and select PDF (Multiple Pages). You're now ready to begin, insert your first page into and then click 'Scan'.
Nov 20, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Fujitsu fi-4120C Path-Through Scanner Logo
570 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
