Question about LG LSC091PMA Split System Air Conditioner
Regarding gas pressure
I have a lg splt airconditioner. itwas giving out hot air and the compressor was getting stuck,. i have serviced my machine and cleaned both the indoor and the outdoor unit.
the vendor says it is low in gas
can u kindly assist me and tell me the actual gas pressure required to run the ac smoothly and the desired temperature at the room.
    Scholar:
  • 149 Answers
Ok lets see how i can help you. If the units low on gas, suspect a refrigerant leak!! 2nd, what refrigerant it's using? I can't tell you operating pressures if you don't know the refrigerant. (usually the label on the indoor unit right side says refrigerant charge and type.) 3rd desired temperature for cooling is about 68-72 F that's about 20-22 Celsius.
id keep it on 21 C
Posted on Apr 23, 2008
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
What is the part number for the piston ring on a ***** air compressor model wl650702aj
You can not buy just the ring. You need piston service kit WL211000SJ
Aug 15, 2014 | Air Tools & Compressors
Switches off after 5 mins
Thermostat click? A leaky pressure switch will cause this.
Stuck fan, causes compressor to get hot and stop.
Dirty coils, ditto.
Blocked outside vents, ditto.
Weak run capacitor, will cause compressor to run hot and stop.
Low voltage from bad breaker, house wiring, outlet, cord or internal switch, will make compressor run hot.
Low on gas, the circulating gas keeps the compressor cool and will overheat quickly if it's too low.
Have a professional check, pretty much in that order even.
Apr 01, 2014 | Heating & Cooling
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
2003 Toyota Echo Power Surge When Airconditioner is on
Air conditioner compressors take up to 5 hp to run that is why when to unit cuts in the engfine revs drop until the computer compensates for the rev drop Can be as much as 700 rpm. conversly when the compressor disengages the engine will over rev until the computer compensates. If you didn't have a problem before but do now it is possible that too much gas was put in the a/c system meaning the compressor is almost locking uo. Have the system pressure rechecked
Jan 07, 2013 | 2003 Toyota ECHO
My regulator adjustment knob is not working and there is no air pressure on the psi regulator gauge. Air goes into the tank and the hose from the motor to the tank gets extremely hot. Is this normal for...
The air discharge hose will normally get very hot. When the pressure regulator valve fails, it may no longer give you air. As a temp measure you can get air out of the unit by removing the safety pop valve and installing a tee fitting in the port. On one side of t fitting reinstall safety. On the second port install a quick connect for full tank pressure. Make sure that there is not air in the tank by pulling on the ring of the safety before you take it off. Replacement parts are at www.toolpartsdirect.com or dewalt service center. Good luck
Jul 12, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My air conditioner stops cooling. Occasionally, it will just function on fan mode even though I confirm that it is on cool mode. Warm air comes out even on the absolute coldest setting. I have to turn it...
If after reset the A/C cools then the fault seems related to the thermostat or the cut off pressure switch or load cut off.
However is there is no cooling at all the compressor and the gas pressure- check for leak if gas is absent.- must be checked .
If compressor is suspect you must check the estimate and decide whether it seems better to scrap and buy a new one.
May 18, 2011 | LG ZW6500R Air Conditioner
Just moved and installed my LG airconditioner. it does not cool, but warms.
Check it's in cool mode and temp setting is 3 degree less than room temp Check compressor is working with required pressure.60 PSI@ 98 degree Fahrenheit of ambient temp.If less pressure or no pressure, gas leak. Arrest leak and recharge gas.
Jan 28, 2011 | LG Heating & Cooling
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
LG C12AWR Air conditioner head fan not working
Check that the fanmotor can spin freely. If not, can be caused by seized bearing on left side of fanblade, or foreign object, insect nest stuck in fanblade. If however it spins freely, check that fanmotor is being supplied with voltage (you sound technically capable of operating a volt meter). If power is supplied, fanmotor is faulty and needs replacing. If no voltage, problem lies with the pc board. If you know someone who is capable let them check the relays on the board. Also you can check that all plug on connectors are making good connection.
Jan 01, 2009 | LG LSC121PMA Split System Air Conditioner
LG LSC091PMA Split System Air Conditioner Logo
208 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
