Question about Goldstar Heating & Cooling
Not cooling looked at inside behind filter and it is frozen
    President:
  • 949 Answers
A frozen evaporator coil means one of two things, a lack of air flow or low refrigerant (freon).
Make sure the filter is clean and the coils are free of dust and dirt. If the unit blows good air (strong flow on high) when it first starts up and then freezes you are low on refrigerant and need to have it recharged.
Posted on Jul 21, 2010
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Water leak inside behind filter possibley the tank
Another possibility is that your filter is not screwed in tightly enough or that its connecting O-ring has broken. Visit this page for new O-rings, https://www.freshwatersystems.com/c-102-filter-housing-wrenches-o-rings.aspx, and this page for replacement filters, https://www.freshwatersystems.com/s-2-replacement-water-filters.aspx.
Jan 12, 2014 | Samsung RF4267HARS Stainless Steel French...
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
Air conditioner is not cooling - how do I check to see if it is frozen?
If it is frozen, you will see frost under the front grill. Remove the grill and the filter - frozen? Let it thaw and start again. Not frozen ... other troubles. You might take the ac out of its case and inspect the inside - excessive dirt on the coils? Wash it off with a hose - do your best to NOT spray any controls. Drain the water and put it back together. If it still doesn't cool ... you probably cannot repair it.
Thanks for your interest in FixYa.com
Aug 19, 2011 | Quasar HQ2052UH Air Conditioner
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
The unit behind the filter is frozen solid.
turn it off thaw out clean evaporator clean filter the grinding is the blower wheel hitting the froze solid. hope the blower wheel is not wrecked. use 409 to clean. Tom
Jun 17, 2009 | LG Art Cool LA121CNP wall/window Air...
Wall ac unit keeps freezing up inside.
Do not run it on maximum cool and fan on low. Freezes up all the time this way.
May 01, 2009 | Heating & Cooling
Side-By-Side GE Fridge Won't Supply Water
Sounds like a frozen line ... press on the inside door lisen to see if there is ice inside defrost the freezer check if water will flow ... if stainless steel door there is a heater kit you can put in... if plastic you will have to replace the door.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Heating & Cooling Logo
79 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
