Question about HTC S710 Smartphone
Micro sd not working
I bought a MicroSD 512MB card for my HTC S710. Phone doesn't pick up memory card?
  • 5 more comments
  • Noosi May 17, 2008
    Got an HTC S710 and transferred the microsd card I used on my 'old' Nokia and the HTC does not recognise it. Two issues:
    1. Can't afford to format the card as it is already packed with 'useful' stuff
    2. Manual has nothing on using the sd card except installtion. Any hints & tips ?
  • Anonymous May 22, 2008
  • Anonymous May 26, 2008
    I bought a 2g storage card for my HTC S710 but my phone keep on sending an Alert your phone is running low on free storage space - why is this?
  • simplyclint Jun 03, 2008
    I have inserted a 4gig sd card in my phone and it did not read, cause I keep getting the same message saying, memory full. My service provider said it was too big and I should by a 2gig sd card. I did and I have the same issue. I have read the posts and solutions posted. Someone posted ( go to file explorer , menu , storage card. ) That does`nt help me cause when i select storage card it opens a blank . There is no where for me to see the memory of the card. So if anybody can help, I would appreciate it tremendously. Thanks, Clint
  • benbriffa Nov 06, 2008
    I recently got a new HTC S710 and have since tried two cards in it being:
    Hama 4GB micro SDHC
    Hama 2GB micro SD
    They are not being read at all my the mobile and i cannot even select them as a storage space in the camera as suggested to similar problems since i do not have that option.
    I do not know if i am doing something wrong, the brand isn't compatible, the phone is faulty or anything else.
    Could anyone help me please? I would greatly appreciate it?
    Hama 4GB micro SDHC
    Hama 2GB micro SD
  • Anonymous May 07, 2009
    My HTC S710 wont read my MicroSD card, it doesn't pick up any SD cards coz i tried My friends cards and it still doesn't read,..what should i do?
K u must go to "file explorer"
the press "menu"
then go to storage card...
Posted on May 21, 2008
    Novelist:
  • 153 Answers
Hi all, many different problems here...
Q: I bought a 2g storage card for my HTC S710 but my phone keep on sending an Alert your phone is running low on free storage space - why is this?
A: its not the memory card that's full its the phone memory, copy some of the pictures music etc over to the card also programs you have installed remove them and reinstall them on the memory card
Q:I have inserted a 4gig sd card in my phone and it did not read, cause I keep getting the same message saying, memory full. My service provider said it was too big and I should by a 2gig sd card. I did and I have the same issue. I have read the posts and solutions posted. Someone posted ( go to file explorer , menu , storage card. ) That does`nt help me cause when i select storage card it opens a blank . There is no where for me to see the memory of the card. So if anybody can help, I would appreciate it tremendously. Thanks, Clint
A: firstly your provider is talking rubbish, these phones will take SDHC and accept theoretically up to 32GB cards.
The card will be blank if there is nothing on it.... see the above answer regarding full memory.
As a test to see if you can actually see the memory card, go to the camera app and change storage to storage card and take a few pics, then go back to file manager.. if you get an error when trying to switch locations in the camera app, there may be a fault on the phone.
Q:Got an HTC S710 and transferred the microsd card I used on my 'old' Nokia and the HTC does not recognize it. Two issues:
2. Manual has nothing on using the sd card except installation. Any hints & tips ?
A:the card may need formating, this will need to be done with a card reader on a PC, at the same time you can copy the information you need to keep to the pc. After its been put into the s710 and the folders have been created you can copy the stuff you wanrt back onto the card.
But remember software that worked on the Nokia wont run on the windows phone, only pictures an music will be useable
Posted on Jun 15, 2008
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem where the HTC S710 was not happy with Kingston 4GB Micro SD.
Solution: insert the card into an adaptor which allow you to plug into your PC card reader, once the PC recognize it, then format it using FAT rather than FAT32 or NTFS, once finished formatting, take it out from the PC and plug it into your S710, go to file manager, press menu and you will see the option storage, change your camera storage from main memory to storage, you will have almost 1500 pictures spaces available for you. Name : Falcon ycs@york-computer-services.co.uk.
Posted on Feb 02, 2010
I bought a 2gig card and tried to install it but the thing would not pick up at all. It turned out that the card was not all the way in. Check that you have the card the right side up obviously and then click it in, when it makes that first click use a pen and gently push it further without forcing the card. Use your phone information page to check if the card is in the system.
Posted on Jun 24, 2008
Sandisk micro memory chip not working in my lg620g cell phone
The LG620g works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work in this phone. You need to use microSD cards, 2GB and smaller.
Nov 30, 2012 | SanDisk 8gb Micro Sd Memory Card Class4...
What is the biggest microSD card can the htc wildfire hold
Hello Dedavi6,
The maximum memory supportable in HTC Wildfire is 32GB. You can use the San Disk 32 GB micro SD card.
Please visit the link provided below :
http://sandisk.com/products/mobile1-memory-products/sandisk-microsdhc
http://www.htc.com/uk/product/wildfire/specification.html
Sep 11, 2011 | HTC Wildfire Cell Phone
How can I add more memory to the Hero 200 phone
you need to purchase a micro-sd card to expand the memory.
May 03, 2011 | HTC Hero Smartphone
Can i use a Micro sd hc memory card in an HTC desire?
Yes! an HTC Desire is compatible with microSD™ memory card (SD 2.0 compatible)
Jul 21, 2010 | HTC Desire Cell Phone
How much of GB micro SD card does htc tytn-2 support ?
THe MicroSD card slot which can handle cards up to 32GB to satisfy your thirst for videos/music/photos/applications. MicroSD cards are now pretty cheap, I saw an 8GB card recently for $18.
http://theonbutton.wordpress.com/tag/htc-tytn-ii/
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 02, 2009 | HTC TyTN II Smartphone
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
Samsung Trace t519 Micro SD
I have this phone to. I remember reading a long time ago, sorry I can't source it, but anything over 1gig the phone will not recognize. I have had 1gb sandisk and 1gb Lexar in my phone no prob. Try getting a smaller size card.
Sep 17, 2008 | Samsung SGH-T519 Cellular Phone
1Gb Micro SD card in HTC P4350
i`m afraid it broken you need buy new one, you can`t do nothing with this one
Aug 13, 2008 | HTC P4350 Smartphone
Micro SD NOT WORKING (SONY ERICSSON W580i)
You need to buy a different kind. i just bought a 4G Microcenter brand and its doing the same thing.
i'd recommend a Sandisk M-2 microSD.
Apr 12, 2008 | Sony Ericsson W850i Cellular Phone
HTC S710 Smartphone Logo
1,416 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
