Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
The washer always seems to have water trapped someplace...when I turn the drum after a load has finished I can hear the water moving around. Now I've noticed a sour smell. Also sometimes at the end of a load the fabric softener cup is full of water. What can I do?
  • 4 Answers
There is a solution inside the inner tub cover that helps serve as a balancing aid during the spin cycle. It is a normal sound on the washer. There is not a problem.
Posted on Aug 16, 2010
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
Water in the washer.
First I would have posted this in the washer section not the vacuum section. That being said:
This is normal for a maytag Neptune. There is a liquid filled balance ring on the Neptune washer drum. That is the sloshing you are hearing. The smell is from the water trapped between the door seal and drum. You can wipe down this seal with an old cotton towel or sock and then throw it in with your next load. Also, just leave your door open a crack after your loads are done and the water will evaporate and not sit and get moldy.
Jan 26, 2014 | Washing Machines
There seems to be water being retained in the machine
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there should be whats cauld a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.Alternatively water might be sigphoning back thru the drain hose into the machine.I hope this was helpfull.
Jun 01, 2010 | Samsung WF337AA Front Load Washer
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Water remain in the machine
the washer has a fluid filled ring around the drum to balance it as it spins, assuming do not actually see or feel water you may be hearing that liquid.
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Feb 24, 2009 | General Electric WBVH6240HWW Front Load...
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
