Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water dispenser doesnt work nor does ice dispenser
ICE MAKER MAKES ICE BUT WILL NOT DISPENSE
wATER IS AVAILABLE TO FRIDGE
  • t_bom Jul 21, 2010
    I suspect this is an electrical problem and i don't have a schematic nor wiring diagram for the dispenser unit.
    Any common switches or couplings that would affect these functions? Both ice & water actuator micro switches appear to be OK.
    Guru:
  • 1,051 Answers
Your referring to the ice dispensing through the door, correct?.
Make sure the dispensing shut is not clogged and the shut door opens properly.
Posted on Jul 21, 2010
  • t_bom Jul 22, 2010
    Checked that.
    Ice door works properly and actuates its micro switch. Also, water dispenser actuates its micro switch. Switches check OK. 110 V is present at the ice & water controls circuit board
    None of the indicator lights on the freezer door illuminate when their button is pressed.
    It would appear that the primary circuit board is faulty.
    I can't verify that, since I have no wiring diagrams.
    The no water and no ice dispensing problems occurred at the same time.
    Any solutions would be appreciated.
    Lacking a solution, does anyone have a source for a replacement circuit board?
    TB
  • 17,970 Answers
Sometime when the water dispenser stops working it is the inlet valve at the back of the fridge. If you do need a part here is a good place to get Frigidaire parts.
Or, its possible that you have any clogged tube I know few fixed by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
You could also try this homemade solution for "no water to the dispenser"... after removing the grate at foot of refrigerator was able to get water to bottom of tube. Careful with the funky little coupling, push the white ends inward to disconnect.
Turned off refergerator for awhile and used a blow dryer to warm up the dispenser area from the outside. Be careful not to damage plastic by over heating. Also tried to warm the exterior of door but not sure if that helped. Used a hand activated vacuum pump on the water exit spout. Took a long time but evidently the water just prior to the spout had frozen. Had run a small metal wire up the tube from the bottom and it went nearly to the area of the dispenser so I don't think there had been any ice except at the area around the dispenser spout.
Hope this helps.
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
168 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
