Question about Belkin (F5D5231-4) Router
How do I set up a desktop through my router? - Belkin (F5D5231-4) Router
  • 708 Answers
Connect the Desktop to any one of the four wired slots in the router
Posted on Jul 21, 2010
I had this router connected to my desktop so my grand daughter could use her labtop,my desktop crashed and I had to replace my hard drive and my memory and lost all information on the router and I lost the...
You actually don't need a setup disk for setting up a router. Try the following steps.
  1. Reset your router to default configurations by holding the reset button for 15 seconds.
  2. Make sure your desktop is set to "obtain an ip address automatically."
  3. Connect an ethernet cable between your router and desktop.
This should get you connected to the router. If you want to make any configuration changes, perform the following steps.
  1. Open up a web browser.
  2. Type in the address bar 192.168.1.1 (Default IP address of Linksys routers)
    This will connect you to the router.
  3. It will prompt you to login. The default username is blank (no text at all) and the password is admin.
Feb 26, 2011 | Linksys WRT54G2 Wireless Router
I unable to connect my desktop through cable but same time i can connect wireless connection with my labtop...now i request you please advise me n help me asap.....
Make sure your ethernet cable is connected properly into lan port and it is working fine.
Make sure in desktop networka dapter driver installed and enable.
ALso check ip settings in network adapter property it must be in your router network settings range.
Set gateway as your router ip in desktop .
if you want ip automatic from router then enable DHCP in router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 27, 2010 | Computers & Internet
I lost my disk to install my router to my desktop pc. How can I get the router installed to my desktop again without the disk?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 19, 2010 | Linksys Wireless-G WRT54G Router
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Loses the connection
Feb 07, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
Not reading wireless connection
The wireless router needs its wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings so the laptops and desktop computers can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 15, 2009 | E-Machines T5048 (7136) PC Desktop
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Internet Connection from desktop
hey laure
you may need to go to control panel, then internet settings, then hit the connection tab, and make sure the 'never dial a connection' button is clicked. then apply and reboot if necessary. don't mess with the router settings and definitely don't restore factory settings, that'll blank out the ip address and other things.
you should be able to access the web, otherwise the ethernet cable fromj your pc to the router is plugged into the wrong port on the back of the router.
good luck
chris from scotland
01776840273
Dec 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D5231-4) Router Logo
35 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
