Question about One For All URC4220 Remote Control
The buttons do not bring up the correct channel IE.BBC 1 I have to press 9 IE.BBC 2 I Have to Type 11 ITV 1 I have to Type 10 Channel 4 I have to Press 8 Channel 5 I have to Press 6
I need RCAtv codes
Posted on May 01, 2008
What is the code for the Emerson HDTV?
hyatis alt="Regular Contributor"> Regular Contributor div.custom-user-badges .custom-user-badge img{ float: left; max-width: 35px; max-height: 35px border: 0; } div.custom-user-badges .custom-user-badges-viewall { font-size: 12px; margin: 0px 0px 0px 10px }
  • alt="The Community would like to Welcome you!">
  • alt="Congratulations on receiving your first Kudos! Thank you for your meaningful contribution to the forum. May this be the first of many kudos.">
Member Since:‎03-10-2011 Posts: 69 Re: remote code for emerson hdtv [ Edited ] what remote do you have?
the best way is to try the search feature....Emerson tvs do not like comcast remotes... ive had a very low success rate. If its a combo emerson tv then i wouldnt even try.
This is for Red select button remote.
With TV on:
Hold down setup button while in TV mode till tv light blinks... Type in 9 9 1 then 1 again, press grey power button once then continue to press channel up button until the TV turns off. Hit setup to lock in the code.
DTA is the same except you just do 991 then start pressing channel up.
Go slow at first it is easy to skip past it and lock in the wrong code. If you press channel up for more then... lets say 2 min... then its not going to work.
good luck
Sep 16, 2015 | Emerson Televison & Video
Unwanted channel display in middle of screen
TO REMOVE CHANNELSscreen13.gif 1. Press the MENU button on the remote control to open the OSD.
2. Press the Navigation (UP/DOWN) buttons to select the Setup menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to select MANUAL SEARCH.
5. Press OK to select.
6. Select the channel you want to delete from the channel list.
7. Press the Navigation (LEFT) toErase Channel.
8. Press EXIT to close the OSD.
Feb 29, 2008 | Televison & Video
How do i type in a channel such as 7.1 ?
I don`t think you can, I have several channels, like 64-1 2 &3, and just have to let the cannel search find the first channel..ie;64, then I pressed remote up one channel, it went to 64-2 etc, hope this helped
Aug 24, 2011 | Polaroid 1720-7 Remote Control
Hi, The number 1 button on my TV remote control takes a long time to fix on a channel like BBC 1 or channels 10 11 etc: Is this curable or do I need to buy a new one and if so from whom? many...
Hi Geoff
If it's only the number 1 button you have this problem with, then it's likely that the membrane is worn and, realistically, you'll need a new remote.
If all keys do the same, i.e 2, 20, 22 and 3 30 33 then it's probably just the response time of the TV. This is so you can enter long channel numbers like 111 without the TV changing to channel 1 or 11 before you have finished entering the channel number. Similarly, if it's on all keys, it could just be a sign that the batteries need replacing.
Anything can be fixed, but in the case of a remote control, the cost and difficulty of obtaining parts mean it's is usually easier and cheaper to buy a new remote.
You can buy replacment remotes from a variety of places, but make sure you are buying a Genuine Original OEM remote and not a third-party replacement. Beware, some shops also charge extortionate prices so make sure you shop around, but you should expect to pay £15-20 depending on which remote you have. I have used the shop below for replacement remotes and they are reliable, but not always the cheapest. Their prices do include delivery though. You will need your remote control model number when searching. On Samsungs this number is usually under the bottom row of keys:
http://www.remote-controls-shop.co.uk/
http://www.ebay.co.uk is also a good source of replacement remotes.
If you have any difficulty finding a replacement or you need any further information, please post back with your model number and I may be able to find you a good deal on a genuine unit.
Please rate this solution if you find it helpful. Thanks.
Oct 21, 2010 | Samsung TV Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
I need to know how to program it to my sony television
To programe the remote you will have to do a code search. Here is how below.
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing “0” performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN
button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP
changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Feb 08, 2010 | Philips SRU6061 Remote Control
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
My SONY TV remote control doesn't do what it should
problem due to dry soldering remote microprocecer
May 21, 2007 | Sony RM-Y135 Remote Control
One For All URC4220 Remote Control Logo
Top One For All Televison & Video Experts
Electro Med Services...
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
