Comfort-Aire RAD-121-5-C 12000 BTU problem
I have a Comfort-Aire RAD-121-5-C 12000 BTU window a/c unit. It seems to work fine as far as cooling but sometimes it just shuts off, and then I can't turn it back on for at least 10-15 minutes. This can happen several times in one day. I cleaned the filter and it seemed to be working better but it is back to doing this. What could be the problem?
  • 86 Answers
SOURCE: fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Posted on Mar 16, 2008
SOURCE: Comfort Aire PAC-121 problem
E4 shows up on the screen on my PAC-121 when the water reservoir on the right-hand-side is not pushed in all the way. If it is in all the way the switch that it engages may be bad or out of place.
Posted on Mar 23, 2009
SOURCE: poison
We searched the internet till we found something that put us at ease. still not 100% but at least 75%-90%.
Posted on Jul 07, 2009
james3751
  • 614 Answers
SOURCE: Remote control for Comfort Aire AC Model # RAD-81C
If you need a remote for your ac unit go to ebay. You can get a universal remote for your unit. Russ
Posted on Mar 25, 2010
icemelts
  • 246 Answers
SOURCE: window unit comfort aire rad
actually it can be charged like a car "if" it has charging ports which it won't have unless someone has installed them - which would only of happened if the unit had a leak previously. So, to answer your question a window unit can be charged like a car but it's a little more complicated than charging a car and I would think you'd need a serviceperson to do this.
Also, if you don't have charging ports already installed on the unit - the chances that you have a leak is not very strong. These are 'sealed' units and really do not spring leaks very often.
I would be more inclined to think you had an electrical problem, i.e. wire burnt off compressor terminal or something like that instead of leak.
Sometimes you can save a lot of money and time - by getting a qualified serviceperson involved.
Posted on Jun 07, 2011
I have a heat and cold comfort aire window unit it blows well but the air is not cold just cool
call an air conditioning repairman sounds like it needs a little recharge and sadly we can not do those ourselves
Jul 23, 2015 | Heat Controller Comfortaire REG-253J 25000...
I have a Comfort aire RAD 101-5 window AC. It works fine until it gets really hot outside and then sounds like it's bogging down and the compressor shuts off.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 14, 2011 | Heating & Cooling
I live in a very small one room studio,and have a comfort aire window unit...air and heat.The heat works real well,but in the spring and summer,I would set the unit on the coldest setting.I can hear the...
Lets look at the output of the system first. Take your square footage of the area you are trying to condition and times it by 15. We try to get 15 Btu's per square foot of air conditioning. If your area is say 10 by 15, you have 150 square feet; times it by 15 = 2250 Btu unit is required. If you have a 5,000 Btu unit, it should be more than enough to cool the room. If this is correct, the problem may be because you have the unit set for Dry. In Dry mode, the compressor will cycle less frequently than if on Cool. If in fact the unit is on Cool, you may need to lower the temperature setting to fool the sensor from turning off the compressor prematurly. If you still can't cool the area, your unit has an issue with either refrigeration or air circulation and will need to be serviced.
Apr 09, 2011 | Comfort-Aire Heating & Cooling
What's the amps for this unit?
Hi, W/D here.
When cooling, it pulls 14 amps.
--W/D--
Feb 22, 2011 | Comfort-Aire RAD-293 Air Conditioner
My air conditioner just shut down like it has no power but the outlet has power. Is there a reset button or something? It's a Comfort Aire Model RAD-151-B
Many window units now have a GFCI plug. If the power cord, where it plugs into the wall, is huge, it should have a reset button on the face or side of the plug.
If not, then a power fuse on the control panel has blown, or the control panel has died.
Aug 14, 2010 | Comfort-Aire RADS-151 Air Conditioner
Mar 23, 2010 | Comfort-Aire RAD-81 Air Conditioner
Fan speed trouble on cool setting
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
