My tv remote for bush 42 inch lcd model number A642F stopped working however the light does flash on the tv when buttons are pressed
Hi ive just had exact same problem phoned customer services and was told it is a child lock all you have to do is hold down the menu button on the tv for at least 20 seconds and all is cured
Posted on Oct 28, 2010
Hi, I have a bush 42" hd A642F the red s/by light is stuck on perm and remote has stopped working ...any idea what problem may be? And is there a code to get remote working again?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 30, 2015 | Bush Televison & Video
Bush a642f tv stuck in standby mode suspect power supply capacitors but all seem ok
Hi
Press and hold the menu button on the t.v (not on the remote) for about a min, this should reset the processor to unlock it.
Aug 17, 2015 | Bush Televison & Video
I have a Philips LCD TV. The remote seems to have stopped working. The TV has power going to it, but I cannot control the volume or select the input with the remote. The controls on the side of the TV...
Take a camera phone and point the remote at the camera, then press a button that you know is working the Tv - you will see a white flash from the remote LED when the button is pressed. If you press a button on the remote that does not work the Tv and you get a white flash from the remote LED when looking at the remote - as if you are going to take a photo of it - then the remote is good and the Tv is faulty. Visa versa, if you don't get a white flash then the remote is faulty.
If the remote is no longer available, then pop it open with a flat screwdriver and wash the remote with a mild mixture of dish washing soap and water. Then let it dry out in the sun until completely dry and then reassemble to try again. I have repaired remote controls in this way for people :)
Jul 31, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
My remote control for bush tv A642F stopped working however when i press the buttons the light on tv still flashes, also when i get the menu up on tv the remote starts working again? I have to press the...
Try keeping the handset menu button pressed for abount a minute, then check the other buttons again, this sometimes works - the set software seems to 'lock-up' causing this problem.
John
Oct 26, 2010 | Televison & Video
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Need code
Try this
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0117
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Pair sky+ remote to tv
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Jan 10, 2009 | LG 42LG50 42 in. LCD HDTV
Configuring Sky remote
3. Press tv again
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Televison & Video Logo
667 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
