My hpnx7010says non-system disk or disk error What do I do no manual purchased from 3rd party HELP
  • chiarelli_ca Jul 21, 2010
    need help in simple terms
  • 10,515 Answers
The steps are explained :-
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=380679&prodTypeId=321957&prodSeriesId=380679&objectID=c00474351
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 21, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Jul 21, 2010
    Thanks for your response!!
    The link is self explanatory. Still, let me recap what's mentioned in that link.As per HP, it is either due to corrupted windows or Bad hard drive.If that is bad hard drive, you need to get it replaced.However, before that you need to reinstall the windows using the original CD that you might have got when you purchase this machine.
    Hope i helped you.
  • chiarelli_ca Jul 22, 2010
    EXACTLY WHERE ON BACK OF LAPTOP IA HARD DRIVE LOCATED ? A LSO CAN A NEW HARD DRIVE BE PURCHASED AND FOR WHAT PRICE ? thanks
  • taran_2005
    taran_2005 Jul 22, 2010
    The cost of 120 GB hard drive for this unit is around $60.However, as i mentioned this error could be due to corrupted windows.It's my humble request, that do not open the notebook if you do not have any electronics repair experience. I could easily tell you the steps, however, if you do not have any experience you might damage the complete machine than replacing hard drive.It is not as easy as it seems to be on paper.
    If you wanted to get reinstall windows and replace hard drive ( if required ), revert and i would be glad to inform you the steps.Make sure for re-installation of window's, you need to have the original windows CD.
    Let me know,so that i could proceed.
    Hope i helped you.
  • 6,993 Answers
the message is referring to your laptop's hard disk. The system is not seeing the hard disk, that's why its requesting for it. The hard disk may have shifted from its normal or disconnected from its position. This could be as a result of carrying the laptop about or moving it from one place to another.
Turn the laptop upside down, while its shut down, located the hard disk, remove it and fix it back. Make sure is firmly fixed and tightened.
Turn the system back on the it should recognized the hard disk. Your laptop will boot up once again, once it recognizes the hard drive.
Good luck.
How do I unfreeze frozen sata port0
If the issue is that it does not see the hard disk on the 0 port ...and it gives you blue screen memory error ..it means it does not have the ahci driver installed ..you need to instal it as a 3rd party ...or ..go to bios settings (press f2 on start ) .select the hdd and under the settings for it ..disable the ahci for sata ..and select ide or ide compatible ..or sata as ide..depending on choices..
save settings with F10 and restart ..It will make the port functional ..
If you want to install with the advanced host controller interface ..than press f6 I think ...when it asks for 3rd party driver ..and try to load it from a usb device by browsing for it ..(in normal mode you need a floppy drive ) ..but it may work ..be sure the usb is enabled in bios..
if it does not work ..than make a boot-able usb memory ..with the operation system ..and use it and insert the driver disk in the dvd drive ..and will work ..This way .when it asks for 3rd party drivers..you will load the raid driver and the ahci driver ..and go on with the installing ..
Feb 06, 2012 | Acer Computers & Internet
What's your problem?How to unfreeze the Port 0 Disk Status in the setup utility for a Aspire 5251-1513?
Dec 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
Inspiron 531 wont boot up. just get dell screen then says Sata 0 Sata 1 Tsst corp DVD sata 2 None sata 3 None
If yo are sure that you have a working operating system on your hard disk , and this error started after you (probably) defaulted the Bios settings or something else did ....Than I think the lack of sata raid driver makes the reading of your hard disk impossible ..To fix this ..either try to reinstall the operation system and during it ..choose to add a 3rd party driver (look for raid driver on your motherboard cd ..or on the manufacturer's support site ) ..or ..just get into Bios again ..look for the HDD in the advanced options ..and select the hdd 0 ..and eliminate the achi feature ..and replace it with sata as ide ..or compatible ..and save settings with F10 and restart ..It will make the hdd visible ..and support installation if it has non ...or just boot up ..but will work as IDE and not raid ..
Aug 23, 2011 | Dell Inspiron 531s Desktop Computer
Professional plus 2007, lost disk have key
Suggest you find a friend or classmate with the program. Load it into your computer, then use your key to complete the install.
Hope this helps.
Feb 10, 2010 | Microsoft Office 2007 Professional Plus...
Write process failed @ 16x PMA update error G: ATAPI DVD A DH16A3L
Guess this a kind of sofware driver, which goes like this "ATAPI ATAPI DVD A DH16A3L ATA Device. & is Optical drives never require a driver when used in any Windowsmag-glass_10x10.gifos from Win95 up. Windows XP (and Windows Vista) provides nativesupport that allows this drive to read a data or music disk and to burna cd-r disk. No support for playing dvd disks or for burning dvd orcd-rw disks. For those tasks, compatible 3rd. party recording & dvddecoding software is required.
If your problem is non-detection, please read post #24 in this thread: http://forums.driverguide.com/showth...t=21669&page=4
It contains instructions on the delete the upper and lower filters fix
Also, there is a STICKY posted in this forum that contains a file fromMicrosoft and instructions that will do this registry editautomatically instead of having to do it manually.
And here's another method that will do this automatically for you if you're afraid to edit the registry manually.
Code: http://forums.driverguide.com/showthread.php?t=22131
(automatic fix, post #7, download file: CdGone.zip) The download is available from
Find it on DriverGuide | Find it with Google ..................sodeep
Sep 04, 2009 | Compaq Presario 5340 (117743-004) PC...
Non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
Inserted non-hp ink cartridges. need reset.
You'll need to be clearer about your problem.
What error messages are you getting?
What cartridges are you using?
Are they refilled or 3rd party cartridges?
... the more information, the more likely I can provide a solution.
May 21, 2009 | HP Officejet Pro L7680 All-In-One Printer
Sometimes Pc restarts
Typically due to a bad driver, or faulty or incompatible 3rd party hardware or software
1. when & how did this problem start?
2. Did you try adding any new third party hardware or software
(This could be anything a PCI card, a new video driver, windows update, a 3rd party wireless card
3. Try a System Restore
4. Remove all PCI cards, uninstall all 3rd party H/W and S/W
5. Try reinstalling all the drivers in the right order
6. Run diags on Memory
7. Repair the os
8. If all these fails, you could suspected memory
Feb 09, 2009 | Microsoft Windows XP Professional With...
Can't install quickbooks 2005 - need flash player 7
open the disk file where qb is and look at 3rd party files
then click flash 7 and ignore when it says error
then the darn thing will install no other solution listed works !
but this just did
Dec 20, 2008 | Intuit QuickBooks: Pro 2005 for PC
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
