Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Water collects at bottom/Ice forms in top
I have a 28-year-old Hotpoint CTF 15 that is lately collecting water at the bottom, under the bins. Thin sheets of ice are also collecting on tops of containers in the top left hand side of the fridge section. Other than that, everything's just perfect!
PS. I love my fridge! If you can tell me exactly how to clear the drain, I'd much appreciate it.
    President:
  • 949 Answers
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Posted on Jul 21, 2010
Hsm25gfra sa. Bought used, was told ice maker didn't work, so haven't hooked any of that up. Problem: water/ice is pooling in the bottom of the freezer section. Every day or two it leaks out. I'm...
The refrigerator has a blocked condensate drain line. In most Hotpoint models it is easily accesed by pulling out the bin at the bottom. There should be a drain grommet at the center of a trough in back. This plugs up. You may have to pour hot water the thaw out the ice and then either blow out the drain tube or I use a 5/15 plastic hose and push it through the drsin to clear it out. this should fix the problen for a long time. Food particles etc. collect in the drain and ice forms around them and blocks the drain.
May 17, 2014 | Hotpoint HSS25GFP Side by Side...
Our icemaker makes cubes, but leaks water from the ice tray area, creating a 2 inch block of ice in the bottom of the ice cube collection bin each night.
Have a look at the manual on page 6 for adjustment procedure.
Also, your leak may be due to a water valve that is not able to turn off 100%. Valve replacement would be necessary. Unplug your icemaker electrical, and empty the ice. Leave the water turned on. If you keep getting water collecting in the bin, you are likely looking at a water valve replacement (not hard at all, just inconvenient).
Oct 12, 2010 | U-Line ULine BI2115B00 Black Echelon 15"...
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
Water collects under the produce bins at the bottom and leaks out
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Oct 11, 2009 | Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Mar 18, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
275 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
