Fax machine not sending or receiving - Office Equipment & Supplies
  • Anonymous Jan 15, 2009
    I have this problem too, my machine is the brother MFC 7840w. It is not sending or recieving, its brand new and recieved 1 fax on the first day I set it up and hasnt worked since. When I put a fax through, it holds it in the memory. Also when I get someone to send me a fax the machine just rings and it doesnt pick it up.
    President:
  • 2,072 Answers
First of all have you pluged a phone into the phone cord of the machine ? Just to verify the phone line.
Is your phone number and ID entered into the machine?
If that information was somehow deleted, that has to be reentered for the fax machine to work. Thats a legal thing.
If the phone line is fine and your ID is properly in the machine and it still is not working then you have a bad fax modem board.
hard to tell you much more without knowing the make or model number.
Posted on Apr 22, 2008
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
Cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers
"cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers"
If your machine can receive a fax transmission from one number, it will receive from all numbers.
If your machine can send to all but not to one particular number, please check that there is a fax machine there to receive it.
You can try to send manually and listen for beeps from the other fax -if one is present- then push the START button to initiate transmission.
If their machine is in working order, the transmission should start. (After the initial 'handshake' of course.)
Jun 16, 2011 | Office Equipment & Supplies
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
My fax machine wont send or receive faxes any suggestions?
If it is properly connected to the jack in the machine and the wall, and it won't send OR receive...then it's NOT a simple problem, because nothing else need be done for the machine to at least "send" a fax.
Dec 15, 2009 | Ricoh FAX1180L Laser Fax
FAX MACHINE NOT RECEIVED FAX I CAN SEND BUT
you need to change your mode key to fax only
Oct 26, 2009 | Brother Office Equipment & Supplies
Not receiving faxes. It will send but not receive
have someone send you a fax. When the machine rings, press START. if this works you are set to MANUAL instead of AUTO
Sep 17, 2009 | Brother IntelliFAX 5750e Laser Fax
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
916 people viewed this question
jasbo
jasbo
