Question about Garmin Nuvi 660 GPS Receiver
No voice announcements , unit does not communicate any instructions like it use to
  • Garmin Master
  • 2,130 Answers
One unit only receives a faint voice communication
Too bad you do not have a 3rd radio for testing. My best guess is you have a bad speaker. Speakers can fail for many reasons. The one I most often encounter is dirt in the grill. It packs in and simply stops the sound. Clean the grill area carefully if this is possible. If new radio, then the manufacturer may have a faulty part or poor installation. I have also seen a glob of glue on a speaker, also making it weak. If you can get a squelch noise, is it loud? If so, I have more ideas. If not, it is your speaker.
Jan 09, 2016 | Radio Communications
Retrieveing a lost recorded announcement
contact your local sheriff's forensics unit and, they can advise you retrieval requires expertise and specialised equipment
May 07, 2014 | AT&T 1738 Digital Answering Machine
How do I turn the speaker on?
You can turn on (or off) the voice guidance ... to announce the driving instructions.
Make sure you select (in your Speaker Preferences) ... the internal speaker ... your Sound is turned ON, your Volume Slider turn up (high), and select (a Voice Preference) as a computer voice... and select the ENABLE Voice option.
In Speech Preference, select the situations which you want instructions/directions/warnings to be read out loud.
Apr 15, 2013 | Tomtom GO 720 GPS Receiver
I have a LG 220 C phone and I am trying to figure out how to deactivate the announcement feature on the phone. My phone is not ringing; it is just announcing the incoming caller's phone number.
Go into the menu. Then hit '8' (calendar, alrms, etc I think?). Press '1' (voice commands). You will then get a drop list to check or uncheck regarding 'deactivate', 'announce', 'announce +ring'. Select deactivate-- now your phone will ring normal! Son had same prob on his phone-- apparently he'd hit 'announce' at some point....
Jan 27, 2011 | LG C 2200 Cellular Phone
How to disconnect the Caller ID Voice?
Hope this helps:
LUsually the unit announces the caller’s
name after the 2nd ring. If you turn on
the answering system and set the ring
count to “2” (page 41), the unit does not
announce the caller’s name.
Or go here to see manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.PDF
Jan 30, 2010 | Panasonic KX-TG5671 Phone
How do you record outgoing message?
RECORD AN ANNOUNCEMENT
1 Prepare your announcement. Each
announcement can be up to 4 minutes long.
2 Press A.
3 Press and release S until you see
the letter of the announcement you want
to record (A, B, or O).
4 Press R. Begin speaking after you
hear the beep. Speak in a normal tone
of voice, about 9 inches from the
microphone.
5 Press S. The system plays your new
announcement. To hear the announcement
again, press P.
6 Repeat Steps 3 to 5 to record another
announcement, or press S.
To assign an announcement to play:
SELECT ANNOUNCEMENT CALLERS HEAR
1 Press and release F until the screen
displays ANNC.
2 Press and release S until the screen
displays the announcement you want
callers to hear (A, B, or O). If you
select AO, you must record an announcement,
as instructed in “Record an
Announcement.”
3 Press S to return to the message display
Jul 02, 2009 | Lands Phones
Gps will not announce street names, highway's, etc. Important note: it had been announcing this data since I bought the GPS in December but just recently stopped doing so.
You have to change the voice to a computer voice. Go to where you choose voices on the main menu Change preferences > Voice preferences > Change voice. Find a voice with the word "computer" in the name and select it. At that point you will be asked what you want to be announced. By the way, this is called "text to speech" in TomTom talk.
May 13, 2009 | Tomtom XL 330 Car GPS Receiver
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
Help! Re-recording message
Following are instructions for the GE25881 phone which is similar to your 25880. Hopefully this will work for you. -Vish Answering System Set Up This section shows you how to set up your answering system to receive incoming calls. Before you begin the setup, you must turn on the answering system. ? Press the conference/ans on/off button to turn the answering system on and off. NOTE: The display shows ANSWERER OFF when the answering system is off. The default status is on. Voice Instructions If you need additional assistance, press and hold the memo button on the base and follow the voice instructions. 12 Answering System Operation Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2 . Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep.
Jul 23, 2007 | GE 25880 Twin Phone
Garmin Nuvi 660 GPS Receiver Logo
42 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
