Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Don't know where to buy eletrostatic filter
Where do I look for new electrostatic filter?
    Problem Solver:
  • 9 Answers
I made the huge mistake of trusting the Delonghi Accessories website.  The white accordion 3M filter for PACL90 is $37.95 and is NOT on the website.  I saw only one Pinguino filter on there and ordered it.  It was the wrong one!  You need to call 800-865-9330 and talk to someone before you try to order it from the site.
Posted on Jun 08, 2008
You have to purchase it from the delonghi website for 10.95. I wish it was available in stores but...it's not ! ergh.
Posted on Apr 25, 2008
Lennox e16q3151p
Take the numbers from the existing filter. Don't have one, then just measure the width & length of the inside of the filter housing. Use electrostatic filters only if your unit is equipped to energize it.
Nov 18, 2013 | Heating & Cooling
My weed eater's fuel lines are busted, do i need to get the whole tank assembly, it looks like their is a filter or float or some sort on the end of the line insisde the tank?
No, you don't need a new tank. You are right about the filter inside the tank.It will make it very easy for you if you can buy the new lines with a new filter attached, but if not, just buy the fuel line.
Jul 06, 2011 | Craftsman 25cc Gas Line Trimmer
The filter indicator is red do u need to buy a new filter if so where can i buy it from and also how and where can i get someone to fix it
I don't know what kind of air conditioner, but I am assuming a window type.
I would turn off or unplug ac unit and remove the front cover. it should just pull off with a little effort and there should be a washable filter in front. just wash it out and get all water you can and reinstall it. there may be some newer styles out there, but this is the only kind I have seen.
Jun 27, 2011 | Heating & Cooling
Aprilia rs 125 2002 model, wont idle properly, airfilter bad condition, if i buy new air filter would it make a difference on the revs when idlin??
Yes, air filter if really dirty,wet or messed up would cause it starving to get proper air to carbs. If that don't do it then next focus on possible fuel filter replacement. Please let me know results, thanks mike
Jun 06, 2011 | 2002 Aprilia RS 125
Drain error still after making sure the washer was level, making sure the drain filter was clean, the drain was clear and replacing the pump motor assembly
LE error? Don't buy a new sensor, don't call a repairman and don't scrap it. The fix is EASY!
Turn the drum 4-5 times by hand to resettle the load, move spin speed to highest, Quick Wash, Speed Wash. It shoudl work just fine. I've had to do this a few times over the last 5 years. Why everyone wants you to BUY parts is beyond me....maybe they need to make some $$ ?
Apr 21, 2011 | LG WM-2277HW Front Load Washer
I would like to know how I can get a manual for an Alen Electrostatic Air Cleaner model KJ25FE-H1. Also I would like to know which air filter to buy for it.
Hi I have found a variety of manuals for you from the alen corp website
follow link http://www.alencorp.com/support.asp?globalnav
at bottom of page is a list of manuals hopefully one is yours if not you could e-mail them
Apr 02, 2011 | Vacuums
Is it difficult to install a new RAM on the e-machine M5305 series laptop?
No, not really but you have to be careful about electronic static. A eletrostatic strap or grounding must be observed before entering the laptop body.
The batteries are located in a compartment on the bottom of the laptop.
there are maybe 1 or 2 screws holding the battery compartment secure.
Proper placement of the new ram is essential to the the installation .
moz-screenshot-2.pngmemory
To remove and install a memory module:
1. Power off your notebook and close the display. Disconnect all cables,
including the AC power adapter, modem, and network cables.
2. Place your notebook upside down on a stable work surface.
3. Remove the memory compartment cover screw and cover.
Before performing any of the procedures in this section,
follow industry-standard practices for preventing
electrostatic discharge. See the Warning note.
To prevent damage to your notebook, remove the installed
battery pack before replacing this component.
this is the instruction from the user manual:
To remove an existing memory module, gently press outward on the
retaining clips on both sides of the memory module 1 until the memory
module is released and tilts upward. Then, pull the module out of the slot 2.
getting started
60
5. To insert a new memory module, hold the memory module at a 45-degree
angle and insert it into the empty memory slot 1.
Gently press down on the module until the retaining clips click into place 2.
6. Replace the memory compartment cover and retaining screw. Insert the
battery pack and reconnect your cables.
The memory module is keyed so that it can be inserted in
only one direction. If the module does not slide in easily,
verify that the notch in the module lines up with the tab in
the memory slot.
Apr 06, 2010 | E-Machines M5305 Notebook
DeLonghi Pinguino PACL90 MODEL
For a short time you can run without filters. I suspect it is low on charge or the metering devise is not working. Check this link out for an owners manual. It may help you.
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Aug 17, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Filter Cleaning
Depends on what type of filter you are referring to. If it is a fabric type filter media these are throw aways. If it is an electrostatic filter you should buy a spare. Wash one use it for 30 days then replace with the spare. Vice-Versa. These need to completely dry before they are put into use.
May 27, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
187 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
