Question about Haier ESA306 Air Conditioner
More heat then cold air is coming out my ac.why?
  • Haier Master
  • 43,501 Answers
Probably a bad compressor and it is getting very hot tring to run but not starting...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
Why does My thermostat Not switch between ac,heat,defrost . there's cold air coming out of vents but not cold enough to be ac. Initially when this started the ac was blowing hot air
If the air flow cannot be controlled from vent/defrost/floor you may have a blend door issue. This is an electric motor that operates a door in the heating system to control airflow. There are usually 3 motors controlling airflow direction,heat and recirculation. The Ac not blowing cold may also be another problem. If the AC is operational, the compressor will be engaged and the Ac low pressure line under the hood will bw cold. If this is all ok then a blend door issue should be suspected
May 09, 2015 | 2006 Jeep Grand Cherokee
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
No heat from vents
Heater blows cold?
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
Cold air coming out on drivers side heat coming
check to see if the vent duct has came loose
Jun 22, 2010 | 2005 Chevrolet Avalanche
Ac does not come on cold when first started when i drive it a mile or so it come on ice cold and stays working till I shut it off 2000 nissan altima
This is normal conditions anything that uses forced air heat or cold there is ambient air in the duct work that must be purged out before the heated or cooled air flows.
Jun 02, 2010 | 2000 Nissan Altima
No heat only cold air comes out i have a 2006 torrent no heat
Well If you can turn on the heater but only cold air comes out you should check the blend door. It controls the door to switch from cold air to hot. It sits directly behind the heater/AC controls. It is white square plastic piece (approx 3in x 5in half inch thick and has a plastic screw rod that attaches to the heater/AC controls and they strip out
Good Luck!!
Thanks
Dec 29, 2009 | 2006 Pontiac Torrent
When on AC the air blows hot, when on heat the air blows room temprature
This is a wiring issue or you have a heat pump and the reversing valve is stuck.
Jun 03, 2009 | Honeywell Electronic Programmable...
Intermittent AC and Heat w/ long gaps of hot(for AC) or cold(for heat) air
I had similar problem on my 2001 Insight. Had to replace some cooling system hoses eaten by rodents... Works like a champ again.
Nov 03, 2008 | 2001 Honda Insight
Haier ESA306 Air Conditioner Logo
51 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
