Question about Samsung DualView TL205 Digital Camera
When ever I try to turn on my Samsung Dual View TL205 the green light just goes on then turns off. I've tried recharging already do you anything that I can do to fix this problem?
    Problem Solver:
  • 6 Answers
Try switching on by holding the button for about 1 minute .WITHOUT ANY BATTERIES IN CAMERA. Then replace batteries and switch on normally. (this should have done a camera "reset").
Worked for me on my camera!
Posted on Jul 21, 2010
Samsung TL205 Camera turns on but the screen never shows any sign of light. Screen is not able to display anything. Can this model be reset?
Many times you can turn the screen off in the menu up settings. Some cameras have a physical button on the camera to do so. Look your camera over carefully, and read the menu settings in your manual. If you don't have that, scroll through all your settings and see if you've turned off the LCD.
Oct 13, 2014 | Samsung DualView TL205 Digital Camera
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
HOW LONG TO KEEP ME CAMERA ON CHARGE
hi,,the charging time is 2 to 3 hours and it depends on the battery that you already consumed, but the only way and not to timed the charging by the indicator light on the usb cable.if green lights appear the battery was fully charged.
Feb 15, 2011 | Samsung DualView TL205 Digital Camera
Camara will automatically turn off when trying to turn it on ....what should i do?
This could be a sign that the battery needs to be recharged.
From the user manual page 16, "Before using the camera for the first time, you must charge the battery. Attach the USB cable to the AC adapter and then plug the end of cable with the indicator light into your camera."
The indicator light will change from red to green when the camera battery is fully charged.
Dec 28, 2010 | Samsung DualView TL205 Digital Camera
My new camera (samsung TL205) will not turn on, when i press the power button I hear a chiming sound but the camera will not power on.
mine is doing the same thing. but my lense wont even close. and when i press the button to power on the green light comes on then beeps, then goes off. so if you get a word on how to fix it let me know.
River
Dec 24, 2010 | Samsung DualView TL220 Digital Camera
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Sep 14, 2007 | Samsung Digimax S630 Digital Camera
Samsung DualView TL205 Digital Camera Logo
691 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
