Question about HP DesignJet 1050c InkJet Printer
HP designjet 1050 C plotter system error 04c3000 25c0000
Printer giving error while receiving job to plot on HP designjet 1050 C plotter it gives system error 04c3000 25c0000
  • Anonymous Mar 13, 2014
    3:10 error showing on hp designjet t1120 mfp plotter
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
  • HP Expert
  • 141 Answers
Either hard drive or network card.
Posted on Aug 22, 2008
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
I have plotter HP designjet 500 24" but when plotting from autocad do not plot in gray color, even though layers as assigned in light colors on the plot style.
You need to set up your pen assignments in Autocad, have you done this? ie, Pen1 is 0,25 black, pen2 is 0,35 blue etc,etc. If this is not done you will have problems with colours and line thickness's.
Jun 25, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hi, I am using an HP Designjet 4520ps plotter and am getting error 84.16:01 - Possible paper jam. There is no jam, it occurs somewhere in the middle of a print job and renders the job a waste. Any...
84.16:01 is a BT arm failure.
In the diagnostics submenu, go to 2.2 BT Arm test. Press ENTER.
If you have a failure, The front panel will display System Error Code 01.0:10.
At this point call HP if you still have a warranty. Otherwise, call a trained DesignJet tech
Jun 13, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
Hp plotter 500ps problem by when given the command affter than plotter show on display system error 81:01. pls give to soluction.
Have you solved this problem, as I post it's 3 months old. This is a serios problem and refers to paper axis shut down.
Jun 08, 2011 | HP DesignJet 500ps InkJet Printer
I have hp designjet z6100, when turn power on it gives empty box on display, and nothing else.
Hi so no error code? I'm sorry to say without an error code to point to the fault is not not going to be a simple job,
I make a living repairing designjets but I'm not supported by Hp, my best advise would be to email Hp and ask for a Maine agent in your area then pin them down to a price to come out and give you a quotation for the repair on your plotter
Yours Ian
Ps if this has been useful please rate me
Mar 10, 2011 | HP Designjet Z6100 InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
923 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
