Question about Vivitar ViviCam 5024 Digital Camera
Every time i try to take a picture it says card locked what do i do?
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
Posted on Jul 21, 2010
Memory card error
Card errors can occur from time to time. Special, when you remove the card while the camera is still switched on. If you have (or think to have) important pictures on the card, please first try to save them. There are special recovery programmes. Several memory card manufacturers do have them. Some other firms also promote them online. To be sure you still have pictures on the card, you could save, find a recover program and most of the time you can use it to recover a few pictures for free. If the program can't find any recoverable picture, you also don't need to buy the program. If there are no pictures on the card, toy can format the card in the camera. If that is also not possible, check if the card is locked. SD cards do have a lock switch. Also you should check if all the contacts of the memory card and in the cameras memory slot are clean and there is no dust or debris in the memory slot.
Nov 26, 2013 | Panasonic Lumix DMC-FX9 Digital Camera
Memory card locked
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 22, 2012 | Sony DSC-TX100V Digital Camera
Every time i try to take a picture "card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 03, 2011 | Samsung Digimax S500 Digital Camera
Card locked
If this happened after the card had been removed then you may have inadvertently slide the card lock into the 'lock' position. If the card has not been disturbed, the very fragile 'switch' may be defective. I would try removing the card and operating the slide-lock several times and then leaving it in the unlocked position.
Jun 18, 2010 | Canon Cameras
When trying to take a picture it says card locked.
The SD card lock/unlock switch has been moved to the lock position. Remove the card and slide the switch (along the edge of the card) to unlock. If it is in unlock, try sliding the switch back and forth a couple of times. Reinsert the card and it should be ready to go.
Apr 06, 2010 | Samsung Digimax S500 Digital Camera
Card locked
There's a little yellow switch on the left side of your memory card labled "lock" with an arrow pointing down. Push it up. Note: If it doesn't work right away, try uploading all your photos to your computer and then dumping them off of the card.  Push the switch up again and it should start taking pictures again.
Dec 05, 2008 | Canon PowerShot SD1100 IS Digital Camera
My casio Exilim will not take pictures or delete pictures.
The lock sensor is faulty. Try clicking the card in and out about 20 times in a row. I am guessing you will need a whole new system board.
Nov 12, 2008 | Cameras
Memory Card
Check to see if the lock tab has been put in the lock position. If yes then slide to the unlock position.
May 08, 2008 | Cameras
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Vivitar ViviCam 5024 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
