Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
Do I need an ethernet adapter with the siemens 587 router? I have an ethernet card that is enabled and working properly but I keep getting an error message saying that I need an ethernet adapter. The tiscali disk won't go any further until I get all ticks on the checklist. I have rang the helpline but not much help there either. Please help, Gary
  • gorillaboy Apr 22, 2008
    Do I need an Ethernet Adapter?
Yes you do need an ethernet adapter
Posted on Apr 22, 2008
  • 85 Answers
1. Test your system with another ethernet card to be sure of the status of your ethernet adapter.
if it works fine that means all is well,if not update the neworking protocols on your computer so that it would be compatible with the routers TCP/IP net. protocol
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Jun 02, 2009 | NetGear WGR614 Wireless Router
My speed stream wireless pci adapter does not work. any time it is enabled it restarts the computer
Hi, you need to follow these steps:
Remove Adapter and Reboot.Download the correct software for your Adapter. For example, there are two versions of the SS1024 driver and they will not work with the wrong adapter.Install the network adapter and reboot.When windows 98se asks you for the location of the driver, browse to the directory in C:\ and select it.From then on, use windows 98se to manage your connection.I hope, it will work for you.
Cheers
John
Ask for any tech Query: +1 (844) 355-5111 (toll-free)
Apr 17, 2017 | Siemens Efficient Networks SpeedStream...
Siemens router & Dynex adapter
Double check if there is any wireless security enabled in your router. Verify if the type of security enabled in your router is already supported by your wireless adapter. If the wireless security enabled in your router is not supported by your adapter, change the security to something that will work with your adapter.
Try connecting your computer with dynex Wireless G USB to different wireless network for further isolation.
Oct 02, 2008 | Dynex Computers & Internet
Home networking.
do you have a pci network adapter intalled with the proper drivers ? did you plug in ethernet cable directly into current pci lan card it will be located on lower part of back of computer? this will eliminate the problems with the router just to see if pci lancard is working or not . if the lan card is working unplug cable and plug in router and then try with router plugged in u might need to reset the router in order for it to work with lan card . if ur using and onboard lan eg attached to the motherboard then you must go into computer bios and enable onboard lan and then the ethernet cable should work with no problem good luck i hope this helps you get up and going getback to me if there are future problems.
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Siemens 587/advent 7096
Hi ,
If the problem is the wrong key entered then you should just modify it in the Access Point settings. Access Point settings can be accessed as Below.
In Tools->Settings->Connections->Access points
delete it then create a new one, or modify it !
Kindly give a feed back for this.
Thanks and regards
Mar 28, 2008 | Computers & Internet
Siemens se 587 router
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Mar 26, 2008 | Siemens SpeedStream 2624 Router...
How to get my internet wireless
You should check to see if you have the ethernet card enables in your laptop, drivers maybe?
Dec 09, 2007 | Computers & Internet
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
74 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
