Question about Protron PLTV-4250 42 in. LCD Television
TV will suddenly go off including the red light indicator while plugged in and power going to it. There is a flip switch right where the cord plugs in. Sometimes you can just wiggle it and the light will come back on and you can turn the TV back on. Other times you have to flip this switch and then flip back again for the red light to come on. I have my visual equipment, DVD, Wii, TV, VHS plugged into an APC battery and everything else keeps running except the TV.
    President:
  • 1,099 Answers
You can fix this by opening the back cover of the television to check for dry soldering , if found resolder , because the likely problem is dry soldering which may cause partial contact making the television to go off.
Hope this helpout
Posted on Jul 21, 2010
When I plug the power cord in the wall outlet, the red light turns on indicating that power is there. when I press the "power on" button on TV or on the remote, the green light turns on for one...
Right now the standby 5vdc is working but it may have gone into safety shutdown due to failed power supply or shorted circuits in the backlight inverter board. You need to troubleshoot it to narrow down the causes first before buying the wrong parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 01, 2010 | Norcent Technologies LT-2722 27 in. LCD...
My son plugged the wrong power cord into Sony Playstation. now when he plugs the right cord in nothing happens. Is there a fuse or something that can be replaced?
is it the power cord i assume ? make sure the little flip power switch above the power cord is in on position. and u should have steady red light on front of ps3 when unit has power on. using a different power cord should not affect it but its not recommended . most ps3 uses a standard power cable.
Mar 06, 2010 | Nintendo Wii Console
My dad cant hook mine up for some reason
Ok
First, Turn your T.V. on and go to the input mode on the t.v.
Second, there should be two cords in the back of your playstation3.
The power cord and the input cord. These are the two basic cords to turn your playstation on.
Once you have them plugged in, on the back of your playstation 3 there should be a power switch right above the power cord. Click it on so that the I is down and the O is up. In the front of your Playstation, a red light will appear indicating that the Playstation is ready to be turned on. Tap the red light until it turns green ( this should only be tapped once) When it is green the system will go to the start-up menu and enjoy your Playstation 3
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
I plug all the right stuff in but its not coming on the screen...i have i fixed to video and everything
Assuming you plugged in everything correctly, (power, yellow white and red) and have set the TV to the proper channel/input, there are only a few other possibilities:
1. Video cord may be bad (unlikely)
2. Xbox 360 may have some sort of hardware problem (would have to ship it in for repairs if it does)
3. TV won't support it. To check that, all you have to do is try it on a different TV.
Oh and something else I remembered. On the end of the video cord that goes into the Xbox, there's a little switch on the side of it. Make sure you have it set appropriately
Good Luck :)
Nov 29, 2009 | Microsoft Xbox 360 Console
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
How do i install an xbox360?
Plug the power unit into to the back. Plug the AV cable to the back of the TV (match the colors) and the back of the Xbox. You'll either use the red/white/yellow if you have a regular tv, or the red/green/blue if you have an HDTV. Then switch the switch on the AV cable to the right setting (HDMI/HDTV or regular TV). Install the AA alkaline batteries in the controller (or the battery pack if you got the rechargeable battery kit). Plug the power cord into the power unit, then last plug the power cord into the wall. Wait a minute for the power unit to light up and then push the big green Xbox button in the middle of the controller down for three seconds and let it go. It should turn on. If not, find someone local to help you. This is all stuff covered in detail in the owners manual.
Jan 01, 2008 | Microsoft Xbox 360 Console
Protron PLTV-4250 42 in. LCD Television Logo
63 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
