Question about Kenmore 15358
How do I thread the bobbin?
I have lost the owners manual.
    Genius:
  • 1,970 Answers
Mcdevito75 here, You can try online at Kenmore.com or Check with any sewing shop in your area.
Posted on Jul 21, 2010
Inky
  • 691 Answers
SOURCE: threading the bobbin
Get a manual from http://www.TheServiceManualShop.com If you do not see it listed ask if they have it off line.
Posted on Jul 03, 2007
SOURCE: thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Posted on Oct 17, 2007
SOURCE: How to thread the bobbin?
use a threader
Posted on Jun 03, 2008
bilabon
  • 46 Answers
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Posted on Sep 02, 2008
  • 1116 Answers
SOURCE: lost instructions for threading lower bobbin how
You can find the instructions at the Singer Company web site - http://www.singerco.com/resources/bobbin_wind.html
Posted on May 09, 2010
How to load the bobbin?
hi Elaine.
  1. Raise the needle to its highest position by rotating the hand wheel toward you.
  2. Removethebobbincoverplatebypushingthereleasebutton to the right. ...
  3. Insert the bobbin making sure the bobbin rotates counter- clockwise when you pull the thread. ...
  4. Pull thread through the slot (A) and then to the left.
  5. go to this link to read up some more.
How to load the bobbin Google Search
Dec 13, 2017 | Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
Bobbin not functioning in my sewing machine.
Consult your owner's manual. It sounds like possibly you don't have the bobbin threaded in the bobbincase properly. The bobbin must spin (either clockwise or counterclockwise per the manual) a certain direction and the thread needs to be threaded in the bobbincase in order for the bobbin to turn.
Sep 05, 2015 | Sewing Machines
How can I get the needle to pick up the thread from the bobbin in my Silvercrest sewing machine
Please refer to your owner's manual.
Usually, you must thread the needle by hand, then that thread will begin to pick up the under thread.
Refer to your owner's manual.
Or locate one online.
Aug 19, 2014 | Sewing Machines
My pfaff 2170 says "main motor blocked" how can I fix this?
It happened to me... Check the bobbin and thread in the shaft ... Pull out the bobbin and remove all thread from the shaft. Pull out any thread remains with the tweezers. Check the feeder dogs and the needle (see Owner's Manual 2:7). Re-insert the bobbin (see Owner's Manual 2:12).Make sure that you use a good quality thread and set everything up correctly. Good luck!
Sep 09, 2010 | PfaFF Creative 7570
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Jul 29, 2010 | Juki TL-98Q
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Kenmore 15358 Logo
64 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
