Question about Homelite Mighty Lite Lawn Trimmer
Can't remove Spool Retainer on MightyLite String Trimmer
Bought reconditioned 26cc Versa took String Timmer ZR21666/ZR21967 and find no way of removing the Spool Retainer in order to replace new .080 string. If there's a nut or bolt in the center, it is cover with a hard
plastic ?? substance. Can you help me?
Orvis Walker
email: orwalk99@verizon.net
  • 708 Answers
SOURCE: Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Posted on Apr 29, 2009
#1 Taper
  • 1041 Answers
SOURCE: Mightylite 26cc Edger
You need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure to clean the small screen in the carb. as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
  • 11 Answers
SOURCE: How do I the automatic string feeder to work and
i dont remember how to put the line on i got a new head. But when the line gets low hit the head of the atomatic feeder on the ground when runin.
Posted on Jun 11, 2009
  • 59 Answers
SOURCE: How do I open the spool of a Mightylite trimmer?
you have to turn the knob to the left to get off then just pull it off and you can get the line back in place
Posted on Jun 27, 2009
rycgl
  • 1545 Answers
SOURCE: My MightyLite 26cc trimmer won't
The possible reason it has always been hard to start is the way the settings on the carburetor were initially made at the manufacturer. Elevation and climate affect these sensitive carburetors but the lower grade manufacturers use a "default" setting on the carburetors. I would say a small carburetor adjustment and mild cleaning (if it has sat unused any length of time) will help the starting issue. Try adding a 1/2 ounce to 1 ounce amount of fuel system cleaner into your 2 stroke fuel can. I recommend Chem Tool Berryman B-12. It has the necessary ingredients to help clean built up gum and varnish in the carb and in the engine. The recommended rate is 1 ounce per gallon of gas, so use about 1/2 ounce in a gallon or 1/4 ounce in a half gallon.
As far as adjusting the L and H mixture screws on the carburetor, first you have to be able to get ahold of them. They are made so you can't. I use a small automotive type plastic wire connector tapped down onto the head of the screw so I can then turn it. I know the heads aren't slotted, or are splined or are D-shaped. I suggest resetting the carburetor adjusting screws to alleviate a hard start issue and a mild cleaning of the carb (through it's own fuel system) to aid in cleaning it up. Here is the manufacturer's suggested methods for setting the mixture screws on your carb.
http://www.zamacarb.com/tipspage.html
Posted on Apr 09, 2011
Starter rope is stuck, will not move when trying to start the trimmer
Smack the the f%%k out of the reel try to get some w/d oil on it then get a new coil reel when smacking watch for string whip
May 31, 2014 | Homelite Factory Reconditioned 26cc...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Shop manual
Try Googling (homelite)(UT20612R)(manual) without parens.
Feb 10, 2018 | Homelite Factory Reconditioned 26cc...
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Cutting blade doesn't move
a homelite is disposable, get a new one. You can pull it apart and see what broke and how much the new parts are. worst case, get the new one.
Apr 26, 2009 | Homelite Factory Reconditioned 26cc...
Oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Jan 17, 2009 | Homelite Factory Reconditioned 26cc...
Homelite Mighty Lite Lawn Trimmer  Logo
291 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
