My dell dimension e520 computer has gotten struck by lightning. It will not turn on. I did some pre test stuff such as I took a paper clip and connected the green wire to the black wire on the 24 wire plug and the fan does seem to turn on. I was told that the motherboard is gone. If you have another way to verify that it isnt gone let me know. Im looking for a place to purchase the motherboard? What kind? Can you give me specifics on the best way to replace the old one and insert the new one and get my computer up and running again?
  • 4,281 Answers
First open the cpu cabinet cover.Then you can see motherboard inside the cpu.Make sure smps power supply of cpu is fine it is square box on top side of cpu.Pull cmos cell from motherboard for 10 minutes then check. If smps is fine and still same issue then you need to change motherboard. Asus or Gigabyte motherboard are best for your computer. You can buy it from below link. Click here Click on above link buy any motherboard listed on above link it is very fast and compatible for your computer. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 21, 2010
  • 1 more comment
  • hoseaketola Jul 21, 2010
    Is that the power supply your talking about the 24 wire? If so I have unplugged it and waiting ten minutes? Do you want me to jump the power with a paper clip again and see if it powers up?
  • ATX cable from smps has 24 pin .Reconnect it to motherboard there is cmos round cell on motherboard pull it for 10 minutes so all settings defaults.
    Also make sure motherboard is not ground with cabinet check it in outside of cpu.
    Then check.
  • hoseaketola Jul 22, 2010
    I tried unplugging the cmos and waiting the ten minutes.. Nothing seems to turn on or light up. I have a yellow light on the motherboard but that the only sign of any power. Is it the main power box? Or is it both the motherboard and the power box. What kind of box do I need?
Switched a vista hd to a xp hd and windows will not open
You can't do that, it just won't work. A hard drive with XP installed on it will be unrecognizable to a PC with vista already installed on it. You can either backup your XP drive by putting it into a compatible XP computer. Or you can buy on of these, which are handy. This let's you get the data to your new PC thru a USB connection.
Mar 26, 2012 | Dell Dimension E520 PC Desktop
My Dvd Drive door will not open. You can hear it trying to open but sounds like something is keeping it from opening.
there is a small hole in front of the dvd drive that you put a paper clip into and push it to open the door it should pop out make sure it goes in far enough
Sep 22, 2010 | Dell Dimension E520 PC Desktop
Where can i find Dell dimension E520 drivers, such as ethernet controller
Access the manufacturer's web-site: http://support.dell.com
Enter the unique "Dell Asset ID" code (black type on a white decal on the back-panel of your desktop computer), to get information about *YOUR* specific computer, including device-drivers.
Sep 15, 2010 | Dell Dimension E520 PC Desktop
I turned off the Dell Dimension e520 before a storm. I have tried numerous times to turn it back on, only to have a yellow flashing light. How can I get my computer to turn on?
Good day.
Here's my point of view of you problem. I have also experienced the same problem since it is always raining here in the Philippines. I just have to ask a few questions before i can give a direct solution to you.
Please provide the following:
1. Do you have a voltage regulator in your computer set. 2. Do you hear a beeping sound everytime you turn your computer on after the incident happened? 3. Does the processor fan still runs after turning your PC on or not? 4. Kindly provide your computer specs.
Good day and should you have any questions regarding the questions, feel free to approach us.
Jun 15, 2010 | Dell Dimension E520 PC Desktop
Dell e520 e deive not accessible
Try the drive in another computer. If this is happening at the bootup process, the drive may have failed or the cable may be bad. Also check the BIOS settibg s to make sure the drive is setup properly.
Jan 28, 2010 | Dell Dimension E520 PC Desktop
I have a problem with my Dell Dimension E520 computer freezes after 15 minutes of being turned
hmm..try check your bios...look at your cpu performance or shuting down temperature...maybe u can disabled shutdown temperature at your bios...or make default setting cmos setup..try that
Jan 15, 2010 | Dell Dimension E520 PC Desktop
My computer has a problem, it is freezes
This is due to any one of your driver is corrupted. Remove the driver one by one and check which gives problem
Jan 14, 2010 | Dell Dimension E520 PC Desktop
Where do I find the usb port on my dimension E520 Dell computer?
E520 has 2 usb ports on the front right where the card readers are. It also has 5 (Five) on the back right where your ethernet cable hooks in.
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Speaker have become staticy. Don't get a clear
Try headphones to see if the audio is the problem or the speakers as a first test.
If speakers have gotten wet or filled with dust/dirt could be the problem.
Wet is fatal, replace them.
Sep 08, 2009 | Dell Dimension E520 PC Desktop
My d drive is full
Hello caliandrew88,
Having a full D Drive will not cause Vista to crash. If you need to free up space then get an external hard drive to move files off of your machine.
- Vincent
Nov 22, 2008 | Dell Dimension E520 PC Desktop
Computers & Internet Logo
62 people viewed this question
Alun Cox
David Payne
David Payne
