Question about Ovens
Oven want stay on. - Ovens
    President:
  • 1,099 Answers
Unplug the power cord and check for voltage at the outlet. Inspect the cord for any damage or burn marks. Because of all the safety devices in a microwave oven, any one of them could be the cause. You will need to remove the outside shell of the microwave. Unscrew the screws underneath and on the back that hold the shell in place and slide it off. Here's a list of things to check that may be causing this problem.
  • The fuse could be blown -- Remove the fuse with a set of fusepullers. Place it on a paper towel so it doesn't roll away. With your VOM set to RX1, place a probe on each end of the fuse. The reading should be zero. If not, replace the fuse with an identical one.
  • Door switch could be bad -- Locate the door switches and remove the leads. With the VOM on RX1, probe the terminals. The reading should be infinity with the door open and zero with it closed. If not, replace. Check both door switches.
  • Fan motor could be bad -- Locate the fan and remove the leads. With the VOM set to RX1, probe the terminals. If the reading is infinity, then it is bad.
Disconnect the power.
Disconnect the sensor harness from the control.
Measure the sensor resistance (white leads).
The resistance should be 1080 ohms at room temp.
If the sensor is open the resistance is usually over 2900 and you get an F3 message.
If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message.
Also look for damaged harness terminals if not a bad sensor.
Hope this helpout...
Posted on Jul 21, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
What make's a gas oven stay on when it's cut off?
Did it stay on for long after you turned the gas off? Maybe it was just the remainder of the gas running through the oven
Oct 31, 2013 | Ovens
My oven pilot light will not stay on
you may need to replace thermocouple and re-try it....good luck.
Nov 06, 2012 | Southbend S560DD (Gas) Oven
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Won't stay lit/hot
call 1800hobart,they are a national chain.
Jul 17, 2008 | Ovens
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven heating element stays on
If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
