Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
I just moved from Minnesota to California and moved my AFD2535DEW Amana refrigerator into my house. It was working fine in Minnesota, but now it does not seem to want to get cold, it runs, but it seems that the seal strip on the left side of the doors is getting really hot, we have it leveled bet am not sure why it will not get cold, even the freezer does not get cold. We had the compressor replaced and recharged in Minnesota, we had to take off the doors of the refrigerator to get it into the house. Please help. Linda Thank you
    Genius:
  • 1,478 Answers
If your refrigerator is not cooling, the problem could be any of the following, follow the steps below one after the order to fix the problem of your refrigerator not cooling.
First of all, the most simplest thing to do is to check the temperature. It might have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it.
Take care.
Posted on Jul 21, 2010
How can I get my freezer door handle to stay on?
If the screws are still good, put some "lock tight" on them and tighten. This should fix the problem
Jun 17, 2014 | Amana AFD2535DEW - 25 cu. ft. French Door...
Repairing freezer drawer slides on amana afd2535dew
if gear wheels are out of sink, give it a good twist till equil.
ifb it is the ballbearings in the rails replace hole rail, wize to do both sides at one time.
Apr 07, 2014 | Amana AFD2535DEW 25 french door bm...
I have an Amana AFD2535DEW. It is over a year old but the top has quit cooling, but the freezer is OK. It did this before, but I was told to let it sit over night with out opeing it. That seemed to...
Mine did the same thing about two years ago. It turned out, my problem was the little motor that opens the vent in the refrig portion to let the cold air in from the freezer went bad. A&E service tech said this was common. Cost about $90 to fix. Haven't had the problem anymore.
Aug 03, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Fridge is not cold freezer works fine.
Try changing the damper settings in fresh food compartment. Your refrigerator has a control board and it is possible the board is no longer working correctly. If your board is bad I can help you locate one. If the fridge is still under warranty I would have the technician come out. He would possibly just change out the board without testing to original board. Other things that could cause problems are thermistor and defrost thermostat located inside the freezer and attached to the evaporator coil. If you continue to have problems, let me know, Thanks, Sea Breeze
Mar 24, 2009 | Refrigerators
Amana Refrigerator ARS9167AB Ice Crush does not produce ice at all.
either the switch is bad that moves the selection from crushed to whole ice or the ice crushing motor is out
Oct 28, 2008 | Amana Refrigerators
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
24 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
