Question about AEG Ovens
AEG Electrolux Oven - Cooling Fan vibrating
my AEG Electrolux Oven (model: SEO 76) is very noisy and sounds like a lot of vibration when the cooling fan turns on. The oven works fine except for the fact that the vibration is very loud.
barkencoa
  • 3463 Answers
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
SOURCE: JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Posted on Mar 04, 2009
barkencoa
  • 3463 Answers
SOURCE: my AEG Electrolux fan assisted oven does not heat
If the fan and light work o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Nov 03, 2009
SOURCE: Delonghi ESM465ST Oven Noisy Fan
I had this on my cooker a few months ago. I took the hob off, (quite time consuming, but not difficult) and found the long fan. Atfer needlessly removing the fan, I found one of the spindals/axles had come out and the fan was unsupported. I just puched it back in and it's been fine since.
Hope this helps.
Posted on Dec 12, 2009
SOURCE: Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Posted on Jan 13, 2010
When i turn on my AEG B4130 oven it makes a low humming noise.Sounds like a electrical relay or capacitor. everything still works including the fan?
210 volts at 60 hertz through the element causes vibration that hums.
Capacitors don't hum, relays click, solenoids would, but doubt you have any.
The element may be failing.
Jul 25, 2016 | AEG Ovens
Vibration/rattle and digital lights flickering
could be the fan,i've seen dust get in there and there's a screen that the fan blows air through to cool down the electronics,so if the fan is bad it's not cooling down your board and that's why the light flicker,how old is the unit,sounds like the board is damaged from over heating most likely from the fan and i looked up the model number and you can't get that board anymore,if the board is bad you could get it rebuilt,i just helped someone else with the same problem the board is discontinued,you have to have the board taken out,draw up a wire diagram and send the board out to have it rebuilt,when they send it back you reinstall it,and wire it.
https://www.appliancetimers.com/appliance?model=gbd307pdt7
maybe if the fan motor gets changed out the board won't over heat anymore and won't give you a problem but it doesn't sound good.i think the board will also be an issue
Nov 21, 2017 | Whirlpool GMC275PD Electric Double Oven
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
AEG Oven Heats But Buzzes
lots of them do it. (Including ours unfortunately) in our case this is down to vibration in the casing the fan is screwed to and can be stopped temporarily by pressing something strongly against the top black casing just inside the grill door with the two ventilation slots in it. I wouldn't recommend doing this every time you need to cook obviously. Ours has done it for years it doesn't get any worse. it's not dangerous ( in my unqualified opinion ) and it doesn't affect cooking performance.
Mar 19, 2013 | AEG Ovens
Very noisy cooling fan.
The only way to fix it properly is to replace the cooling fan I have tried every other way possible at some point
Apr 21, 2012 | Electrolux EOG6330 Gas Single Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
ERROR CODE F6
F6 error code relates to the power board excessive temperature,this points to the cooling fan situated on top of the oven unit being faulty.
You already said it was noisy which is most certainly coo;ing fan.
Hope this helps.
Apr 16, 2010 | AEG CB8920-1-M Electric Single Oven
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
Ovens Logo
172 people viewed this question
Top AEG Ovens Experts
Sal De
Steve
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
