Question about Shure Beta 58A Professional Microphone
Beta microphone when am recoring my mic produces a slight sound even when it's off
    Problem Solver:
  • 10 Answers
Dear friend, your best bet would be to try a different cable and to make sure the ground of your machine is properly connected. It could also have something to do with your audio interface, but I would need more info to be able to help you on that.
All the best
Cass Surek
www.surek.co.uk
Posted on Apr 22, 2008
Shure beta 57A ..low recording volume from acoustic piano ...Directly to laptop no mixer used
are you using an interface?
Your level will be always be lower if you are going straight in.
Your interface and mixer will help you get the correct level in to your system before recording and also shaping the sound after the recording.You just need to get more gain up in there
Feb 04, 2013 | Shure Beta 57A Professional Microphone
My mic has a faint sound
Have you tried other microphones in this circuit or connected the microphone to another cable. If the problem stays with the microphone go to shure.com, look under support to find information on repair. If the problem does not go with the microphone you have another problem. Of course it could simply be indicating the gain has been turned down on the sound system.
Mar 20, 2012 | Shure Beta 58A Professional Microphone
I have set-up M-Audio microphone recently but I can't seem to figure out HOW to begin using it. I've tried every drop down and clicked every recording button while I was using the software. . . is there...
Without knowing your setup or the mic model, my guess is that you need to run a phantom power supply to the mic to get it to function. This is done either by using an outboard analog mixing console or mic preamp with a phantom power switch, or using an inline phantom power supply. The microphone plugs into the mixer or mic pre with the phantom turned on, and then into your DAW system.
The phantom power works with condensor microphones like the one you have. It sends a 48v signal to the microphone element, which in turn energizes the element and makes it function. Dynamic mics, like a Shure SM 58 for example, do not need the phantom power and will even ignore it if run on a phantom powered channel. condensor mics however must have it to function, otherwise there will not be any sound. Hope this helps. Good Luck.
Mar 19, 2011 | M-Audio Producer USB Microphone with...
How find orginal shure mic?how? and how to make cable? what is balance and unbalaned cable? better balence ya unblance cable
Unfortunately, there are many counterfeit Shure microphones out there. Each of the counterfeit manufacturers makes the fakes slightly different. Thus, there is no one thing to look for. The best thing to do is to purchase the mic from an authorized Shure dealer. Then, you can trust that it will be genuine.A balance cable has three wires (such as XLR connectors), and unbalance cable uses just two wires (such as a two conductor 1/4" connector.
Jul 28, 2010 | Shure Beta 87A Professional Microphone
Can't record clear sounding video on either my mini or my laptop.
A better idea is to use a digital camera with sound, switch to video record and make your video with that then copy that AVI file to your PC. But if you really want to use the PC make sure that your Audio source is selected in the recording devices section of audio properties as Microphone, then turn off mic boost. Slowly bring up your mic volume with the headphones attached until you can hear yourself clearly. Cranking it up too far will result in over-modulation and distortion. And finally, remember that most microphones included with laptops and Desktop PC's are cheap hetrodyne models with limited filtering and cheap plastic domes for audio pickup. The more you pay the better they get.
Something worth mentioning here.
I have actually had success recording with Cheap headphones on the Mic port before. Not headphone mic combos, but the actual Headphones. This gives you an idea of the sensitivity of these pickups.
Mar 14, 2010 | Computers & Internet
Is my new Shure Beta 87A microphone a fake
Unfortunately, there are many types of counterfeits out there. So, differences that you see posted online might not apply to all counterfeits.That is, various factories in China produce the counterfeits differently. The best thing to do is to completely avoid unreliable sources, such as eBay and Craigslist. Be extremely suspicious of any products on the internet.
Jan 28, 2010 | Shure Beta 87A Professional Microphone
I have a 57abeta radio mic. Everything appears to
Please check if the gain in the microphone is open.
Ther's a little hole where you can adjust the gain.
Good luck,
Gerard
Dec 20, 2009 | Shure (LX287CC) Professional Microphone
The Beta 58 I purchased ( as a floor sample) has a "nasally" sound.
There are lots of copy Betas out there.
It is probably a PG58 or Chinese copy.
A new cartridge retails around £85 GBP.
Apr 04, 2017 | Shure Beta 58 Microphone
Inputs
ok, heres what try contacting the support line on your samson mic and ask the setup if you are going to connect an acoustic guitar, there might be some info for it. actually there is here check this out
Acoustic Guitar
There are a variety of ways that the G Track can be used to mic an acoustic guitar. The
microphone placement will depend on the type of instrument and what kind of sound
you’re looking to capture, for example the tonal quality you want to focus on, and how
much finger slide or pick noise you may or may not want. When miking a standard
steel string acoustic, a good place to start is with the microphone positioned pointing
towards the end of the fingerboard at a distance of about 6 inches to 2 feet away from
the instrument. You can experiment by moving the microphone slightly in the direction
of the sound hole, which will produce more low frequencies, or move it in the direction
of the fingerboard to capture more high-end or to remove any unwanted boominess.
For nylon string acoustic, try positioning the microphone above the bridge to emphasize
more of the attack from the sound of the finger picking, or for less, move the mic closer
to the sound hole. If you have a pair of G Tracks, try one positioned at the fingerboard
and the second over the sound hole.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Shure Beta 58A Professional Microphone Logo
32 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
