Question about Lightning Audio Bolt B2.150.2 Car Audio Amplifier
I bought this amp at a pawn shop and would like to know what sub woofer would work well with it?
  • 70 Answers
You can try a MTX 10" 5500 or a 10" alpine type R
Posted on Aug 03, 2010
I have a pioneer ts-w304r 12" subwoofer with a Dual Xpr520 400 watt amp, and a kenwood kdc-bt742u head unit. everything is hooked up properly. i know for a fact, and the head unit has all subwoofer options...
bad sub or amp. test your sub with a 9-12 volt battery not a car battery!!! more like a drill battery with low amp rating (don't leave power to it very long or could wreck your sub coil). if that work. then test your amp with a working output if you have a friend with a system hook it up in there car to see if it will work. pawn shops test amps tell them you want to sell it and they will test it and then decline their offer. lol just thought of that on the spot.
Mar 11, 2015 | Pioneer Car Audio & Video
Need sub woofer
Any powered sub woofer will work. Just hook it up to the sub pre out with an RCA Cable.
Aug 02, 2012 | Aiwa AV-D57 Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
Amp not working properly
yes that is the cause sorry..i have done it before when i was younger a few times thats how i know..sorry man
Dec 05, 2008 | Car Audio & Video
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Lightning Audio Bolt B2.150.2 Car Audio Amplifier Logo
95 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
