Question about Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Pasquini Livia 90: heats up for about 5 minutes, then turns off and cannot be used again until it fully cools
    President:
  • 1,618 Answers
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Posted on Jul 22, 2010
How do i replace a touch pad
See user's manual, if any hint. Actually, didn't know that asquini Livia 90 Espresso Machine has a touchpad. Looks a really interesing device!
https://www.seattlecoffeegear.com/assets/user-manuals/pasquini/pasquini-moka-grinder-user-manual.pdf
May 13, 2015 | Pasquini Livia 90 Espresso Machine
Machine shuts off after a minutes
It sounds as though the steam being released with the valve a little loose allows some exhaust. When it is tighten up there is a sensor on them that will shut it off automatically for safety reasons. more than likely that sensor is broke or there is some type of clog cause there to be to much pressure and heat which in turn trips the sensor and shuts it off
Jul 02, 2012 | Pasquini Livia 90 Espresso Machine
This Livia 90 has been working beautifully for the last 5 years. Suddenly, the water does not heat up. The needle on the temperature gage reaches the point just before the red marking and then gradually...
Hi
If you open the steam knob before you turn the machine on and it heats up normaly, you need to replace the vacuum breaker valve on top of the boiler. Its the 3/4 hex nut with the little brass pin in the center. If its is stuck closed when the machine is turned off, its holds pressure in the boiler, so when you turn the machine on again it starts to heat up but reaches pressure fast and turns the element off before it heats up all the way.
Apr 25, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
My husband removed the steam wand from our Pasquini Livia because I am running out of steam too soon and I thought the wand needed to be tightened. Now we need to know exactly how the springs go back when...
There should be a brass disk also. The spring goes in first, then the brass disk with the curved side down, then the wand, and then the nut.
Low steam pressure, could be a sign of scale build up, or the heater is getting covered with sediment. The heating element is on the bottom of the boiler on a Pasquini. Also check you pressure gauge. It should b shutting off at 1.1bar of pressure. If it is lower that could be another cause of low pressure. It can be turned up by the pressurestat.
Aug 24, 2010 | Pasquini Livia 90 Espresso Machine
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Where can I get an owners manual for a Pasquinin, Livia 90?
I found a writeup about this machine below. It has a great deal of information that may help you out:
http://ix.cs.uoregon.edu/~michal/espresso/livia-90.html
Additionally, you can contact the maker directly, and they should be able to supply you with a printed owner's manual. Their web page is below:
http://www.pasquini.com/
Sep 28, 2009 | Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
350 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
