Question about ASUS AC Adapter- Universal Notebook AC Power Adapter (NBACA407D2) Power Supply
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
    Novelist:
  • 184 Answers
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
Posted on Sep 14, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 18 Answers
If it's new then take it back. Attempting to fix it may void the warranty, so leave it alone. Tell them you suspect the power socket has come loose from the mobo and you want a new one, not a repair. If off warranty then wiggle the cord prong inside the socket while watching your power indicator. If it goes on and off then the power socket is bad. Have it fixed.
THIS ONE IS BEST ACCORDING TO YOUR REQUIREMENT
http://www.laptop-battery-chargers.com/asus-adp-150nb-d-ac-adapter.html
Posted on Mar 19, 2012
How do I fix ASUS 1225/R252 Series, specifically the ASUS 1225B netbook WILL NOT POWER ON?
Is the machine processor way clean dustfree, is the bootable block of the drive damaged ? or ..... ?
If you are have do all the things read here on bleeping computer first how to take the right way , because of the different options by these kind of problems.
get always a life linux cd or a redo cd to get your maps with programs and maps to get it of it or to copy it to an other computer
THERE ARE MANY PROGRAMS BUT BE CAREFUL WITH IT.
http://www.bleepingcomputer.com/download/combofix
Dec 23, 2015 | ASUS Eee PC 1225B AMD E-450 1.65GHz...
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
Benq joybook lite
Batteries only have a useful life and once it is used up they have to be replaced.
If you can get on the laptop and work without any problems using your AC Adapter and Power Cord then the battery is definitely dead and needs to be replaced.
If you have problems using your computer using the AC Adapter and Power Cord then either your Power Cord is Bad or the DC Power Jack where the power cord plugs into the computer is bad. If either of these two is bad they will not charge a Good Battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 04, 2012 | Acer Aspire Computers & Internet
ASUS AC/DC adapter not working
Replace it, cheaper in the long run.
Mar 29, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
It wont charge my netbook
Is your ac adapter or charger detected?
If YES, and it doesn't charge the battery, but it turns ON the laptop it means that the battery is the one not holding a charge.
If NO. Try to change the power cord that goes to the wall (that part is detachable) with good known power cord. If it does the same then definitely there's a problem with the ac adapter.
If the computer powers ON, both ac adapter and battery are detected but no display, then the problem is the system board.
Hope it works.
Mar 15, 2011 | Computers & Internet
I have an ASUS eee netbook. Recently the power cord hasn't been connecting well to the computer and now it doesn't even register. It's plugged in but isn't charging. Is it the cord or the laptop?
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2010 | ASUS Computers & Internet
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Blue power cord light is on, but computer does not power up or charge battery.
you can try the following:
  • Remove the battery and connect just the AC adapter and try to boot up. If it works then install the battery, if not
  • Remove the battery and AC and press the Power button for 30 sec
  • Under the netbook, ( when turned upside down) on the right-side near the windows key sticker you will see small hole use a pin to press this button. This will reset your HW.
First 2 solutions worked for me. I had issue with my battery calibration. After leaving it 24h on the AC all back to normal.
Hope it helps
Oct 04, 2010 | ASUS Eee PC 1000H Laptop
No power
Try to remove your battery and plug in your AC adapter
If its working:
You need to replace your battery
If its not working:
Try to check if the LED indicator is lit
If the LED indicator is not lighted. Replace your AC adapter
Thanks. Cheers!
Apr 20, 2010 | Acer Aspire One AOD150-1920 Netbook
Open Questions:
See all ASUS AC Adapter- Universal Notebook AC Power Questions
Computers & Internet Logo
957 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
