Question about Gateway 310S (2900621) PC Desktop
Hard drive I'm trying to install a new hard drive, but when I try to do it using my windows xp it only goes to a point and then tells me hard drive not detected. what am I doing wrong? Does it have to do with the BIOs? if so how do I fix it so I can get back on my computer? PLEASE HELP! my name is Stella
  • Anonymous May 01, 2008
    im trying to install my hardrive but im not able to do so and ist given an error/
    Genius:
  • 2,785 Answers
Is your hard drive internal or external. i am assuming your drive is internal,plz put the drive in master slave configuration. if your older drive is in master then use the new one as slave and vice versa.to do this you have to put the jumper in the appropriate pin.plz post your findings
Posted on Apr 22, 2008
I have a Dell XPS 600 Desktop. I have a new HDD SATA. I installed the new HDD and I try install Windows XP by pressing F12 to boot from disk. It take me to a screen where it says, Press enter to install...
Don't press F12, that tells the Dell to restore Windows from a hidden partition located on the original hard drive. Since you are using a new drive, you need to boot from the Windows XP CD and follow the instruction to load the operating system.
Oct 30, 2010 | Dell XPS 600 PC Desktop
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Jan 24, 2010 | Computers & Internet
I have recently had to install a new hard drive. now my speakers say ''no audio device detected'' I have tried reinstalling the drivers that came woth the comuter - says ''not installed'' after I go...
If you are able to identify your Motherboard model, your problem is 80% solved. Find the model and check for the driver in the manufacturer;s website
Nov 15, 2009 | Microsoft Windows XP Home Edition
Sony vaio does not recognixe new hard drive
what was the os earlier is it a xp ? ..... check it on the BIOS whether hard drive is detecting or not
Sep 08, 2009 | Computers & Internet
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
1. Boot the computer using the XP CD. You may need to change the boot order in the
system BIOS so the CD boots before the hard drive. Check your system documentation
for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery
Console, press R", (you Do Not want to load Recovery Console). I
repeat, do not choose "To repair a Windows XP installation using the
Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows
installations.
5. Select the XP installation you want to repair from the list and press R to start the
repair. If Repair is not one of the options, END setup. After the reboot read
Warning
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any
key to boot from CD when the message appears. Setup will continue as if it
were doing a clean install, but your applications and settings will remain intact.
Apr 05, 2009 | Computers & Internet
Cannot install windows xp
If your hard drive is NOT a SATA hard drive, try looking on the back side of the hard drive, and see if the jumper pins are set at "cable select". If they are not, this could be the problem. Once the pins are configured correctly, this should solve the problem.
Apr 03, 2009 | Chaintech AMD (7VIF4) Motherboard
Hi, i am unable to install windows XP in pavilion dv6500 laptop. XP set up is not detecting the hard disk at all can you help me ?
Some copys of windows XP can not detect a SATA hard drive what you need to do is get hold of a later dvd copy of XP only the lastist dvd copys of XP are setup to detect SATA hard drives. It has to be a DVD copy as the CD copys do not detect SATA drives. Find some one with a new computer with SATA drives that has windows XP installed on it and try there copy of XP on your computer. Hopes this helps.
Jan 31, 2009 | HP Pavilion DV6500T Notebook
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Gateway 310S (2900621) PC Desktop Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
