Question about Whirlpool Washing Machines
Hi i have a whirlpool washing machine AWZ 510/S E. the red service light keeps coming on after a wash and i'm just wondering what it wrong. it is working fine otherwise. what could the problem be?
  • 65 Answers
SOURCE: Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Posted on Feb 18, 2008
kjmac
  • 97 Answers
SOURCE: Whirlpool AWO 5140 Service-Red-Blinking lamp
hiya
it could be something thats been stuck in the pump filter, usually on whirlpools these are located at the front of the machine behind the plastic kick plate on the bottom. you may need a couple of towels or old rags as there will be some water comes out of the filter when you remove it.
hope this helps
Posted on Jul 31, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
SOURCE: My Washing machine stains clothes;
I've had this problem for many months now.  Even when it ruined my favorite tops & jeans, I couldn't get myself to let go of them... Good thing though because I have found a solution!  Make a paste using cream of tartar and hydrogen peroxide.  Generously spread the paste over the stains and let sit for about 5 minutes.  Boil enough water to fully immerse the stained garment in.  While waiting for the water to boil, figure out a way to wrap/roll the garment so that the paste doesn't come off when put into the water.  You want the paste to melt onto the stain while in the hot water.  After wrapping/rolling the garment, secure it with string or thread (anything that won't melt) that doesn't have color, just in case it bleeds.  After the water has come to a full boil, immerse the garment into the hot water and let it soak.  After about 15 minutes, remove the garment from the water.  The water should still be very hot, so I use cooking tongs to get it out.  Let the garment cool down to room temperature while still rolled up.  After it has fully cooled, unwrap the garment.  There should be very little or none of the paste left on the stain.  If there is still a great deal of paste, you may want to soak it again until the paste melts a bit more.  Once the paste is gone, rinse of the garment and it should be clean & stain free.  :o)
Posted on May 03, 2009
I want to Know how to use each button?
Try Googling (whirlpool)(AWZ 410 - 1000)(manual) without parens.
Dec 25, 2017 | Washing Machines
Awz 412 washing machine/dryer.
With a washer and drier thay do , a separate drier would be better for you
Dec 13, 2017 | Whirlpool Washing Machines
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Washing machine not switching on no lights coming in control panel
Check that all the many wire connector plugs are seated correctly
on the board
Oct 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
Hi the red service light has come on and wont let me wash please tell me what is wrong with it thank you very much
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out, the red light is telling you to clean that part
Jul 13, 2011 | Whirlpool Washing Machines
My washing machine seems to keep filling up and then after so long the red light comes on to say tap is closed - tested all pipes etc - do not know what to do
SORRY BUT DO NOT WANT TO GIVE MY CREDIT CARD DETAILS OVER THE COMPUTER - NOT RELIABLE.
THOUGHT THIS SERVICE WAS FREE OF CHARGE FOR WHIRLPOOL
Jun 22, 2009 | Whirlpool Washing Machines
Where to find quick guide of whirlpool AWZ 475
I have moved into an apartment with a whirlpool AWZ475 washing machine with no instructions. Is there somewhere I can get an operators instructions on line ?
Mar 04, 2009 | Whirlpool Washing Machines
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
184 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
