Question about Sony KV-35V65 TV
Sony kv35v65 tv red light light blinks repeatedly continuously no set number of times, sometimes pic will turn on then the horizontal lines will fade going towards the top of the tv then go black what do you you suggest? thanks
Looking for a flyback nx 3005 for my sony kv35v65
Posted on Aug 18, 2010
When I press button to turn on my Sony 32 Sony Triniton TV, I hear clicking noise as if TV trying to come on, but it does not come on. The red light for Standby keeps flashing, but, TV does not come
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any.
Feb 04, 2015 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
My sony kdl46w5100 tv shut off by itself and when I turn it back on it shows no picture and shuts off again after 5 or 10 seconds. red light blinks 13 times then 14 times and then repeats 14 times...
13 times blinks denotes a short circuit inside the horizontal output stage circuit. Contact any service technician. If you wish to get more details about blinking codes to Sony TVs, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 25, 2013 | Televison & Video
I have a sony KP-65WS500 Ztv turns on but screen is blue with lines. I can hear sound but cant get tv on.the red light blinks five times.. Does anyone know what is the problem?
Can you confirm the actual model number of this set? Some had issues with the picture tubes being bad but depending on model number there may be a fairly easy way to adjust around this to correct the issue.
Apr 27, 2012 | Sony KP-65WS500 65" Rear Projection...
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
WHEN I TURN ON TV I GET A RED SCREEN WITH HORIZONTIAL LINES STAYS ON FOR 10-15 SECONDS THEN TURNS OFF STAND BY LIGHT BLINKS 7 TIMES SORRY THIS IS A SONY KV35V65 TV
this is a red retras line problum
[1] red cathoud video amp. trangester is sort or dry canaction
[2] red cathoud is sorting with filament terminal is in side pictur tube
so pls. cont. your nr. tv. tech. solve this problum. it is not very expancive
* this is a coman problum if your tv set is 7 to 8 year old.
Nov 10, 2009 | Sony KV-32V65 TV
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
