Question about Dolphin Maytronics Diagnostic Robot Cleaner
Unit is in the water. You can tell water is being sucked in but tracks won't move. I have turned off at the outlet for days still the same.
    Problem Solver:
  • 7 Answers
... try removing the side panel to expose the drive belt and make sure there is nothing lodged in the drive belt.
Posted on May 29, 2011
Suck hoover
If the wire is underneath the unit it won\'t suck up the water. I did this once. Make sure it is flush with the floor.
Nov 11, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Tip
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
on Dec 16, 2009 | Dolphin Maytronics Diagnostic Robot...
My compact refrigerator won't turn on after a defrost
change the regulator... your regulator is faulty
Oct 09, 2012 | Traulsen Refrigerators
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Does it have to be in water for it to start.
Yes, works by sucking water which causes internal gears to turn, making unit move.
Jul 24, 2010 | Aquabot In - Ground Robotic Pool Cleaner
I have a kscs25inss kitchenaid refrigerator. I opened the door and there was no power, the unit was not running (no compressor, no lights, no water). The circuit breaker did not trip, but I reset it...
Hi, Most likely the outlet has a loose wire or the cord for the refridgerator has a loose wire. Check the outlet on the wall see if it moves at all or has any loose wires in the back...if that looks ok replace the cord to the refridgerator. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Sep 18, 2009 | Refrigerators
Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
May 31, 2009 | Zodiac Pacer Pool Cleaner
Cleaner not sucking up dirty water.
try stripping it down and cleaning all parts and filters .some cleaners use a safety 'ball' to stop water getting on the motor is this stuck it should slide up and down a small track in a tube..good luck hope this helps farr64.
Apr 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dolphin Maytronics  Diagnostic Robot Cleaner Logo
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
