Question about Berenson 2 POST TISSUE HOLDER POLISHED NICKEL BER2112US14
How far apart do we install tissue holder posts
    Master:
    Sergeant:
  • 383 Answers
Read the instructions
the best way is to fix the fixture as if it were already installed, then just screw it in
level also help
Posted on Jul 22, 2010
My kohler toilet tissue holder came off the wall...how to you separate it from the metal wall mount to rescrew it into the wall...it looks like a special tool is used..
Hello - most toilet tissue holders have a allen screw head or a eye glass screw head that holds them together, they need to be separated,remounted to wall then put back together. P2 Plumber 25 yrs
May 18, 2011 | Kohler 10554-BRZ Devonshire Toilet Tissue...
Moen eva tissue holder broke, how do we fix it?
Specifications and Installation Instructions:
http://www.moen.com/shared/pdf/yb2808sp.pdf
Identify the parts needed and the part number from above.
To order replacement parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=YB2808CH
If your tissue holder has simply come loose it is likely the the wall mount will need to be replaced or at the very least tightened. You will need to remove the tissue holder from the mounting bracket. Insert a small flat screw driver in the square hold at the underside of the base of the mounting post to release the locking tab. Try to tighten the screw holding the mounting braket; if it will not tighten you may need to replace the wall anchor. Once the wall anchor is replaced you can reinstall.
Apr 02, 2011 | Home
Need rough in dimensions for delta R11000
Wondering if you have you model number confused; the Delta R1100 is a shower flow diverter; see here:
diverter-rough-in-for-custom-showers-used-with-rp42410-to-replace-delta-r11600-diverter/p1430641">http://www.faucetdirect.com/delta-r11000-3-6-setting-diverter-rough-in-for-custom-showers-used-with-rp42410-to-replace-delta-r11600-diverter/p1430641
The installation guide and spec sheet is available for the above on the web page.
Currently available Delta Tissue Holders can be seen here:
http://www.deltafaucet.com/bath/accessories/filter.html#11051218525_
None of the model numbers are close to what you have provide. Perhaps you can pick out the model closest in appearance to yours. Links are available below each model for the dimensions and installation instructions.
Mar 01, 2011 | Delta Faucet Company Innovations Polished...
I need to replace the screw in Grohe 40296000. What size is the screw?
call grohe they have a lifetime warranty and should send you the screw
Nov 30, 2010 | Grohe 40296000 Chrome Tenso Tenso Single...
How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
The technical specifications and installation instruction for your product are available here.
http://www.moen.ca/shared/pdf/yb2208sp.pdf
At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
Nov 15, 2010 | Moen YB2208CH Brantford Toilet Paper...
HOLDER SEPARATED FROM WALL. DON'T KNOW HOW TO GET
There is probably a hex-head set screw on the bottom. If so, unscrew and that should allow access to mounting screws.
Nov 06, 2009 | Gatco LATITUDE?² TISSUE HOLDER - EURO...
Toilet leaks sometimes
Check washer in float valve assembly. Could be overflow when toilet has not been used for some time.
Jun 25, 2009 | Allied Brass Continental Collection 2 Post...
How to remove the mounting flange from a circular, one-arm toilet paper holder, so it can be re-mounted? there is no set screw to release it-- the flange has two screw holes on either side of a center...
you will need a vary small flat screw drive and at the bottom of the holder the is a small hole insert screw driver and un screw, it has a small screw that holds to the plate on the wall
May 05, 2009 | YORKSHIRE 5308 - Yorkshire Paper Holder -...
Fencing
I am trying to install some heavy duty mesh fence to round fence posts. The corners are difficult because the posts were to far apart(11') to use the same 3.5 diameter that I use for the post for the corner rails. The best thing I found for it was 3.5 in square after doing a lot of research. Now I am not sure how far above the bottom of the pole to install it. I was going to use lag screws to screw it threw the fence post into the square top rail. Where should the top rail be in relation to the top of the wire mesh? The mesh is 4' high. Right now I have a 2" gap.
Apr 02, 2008 | Computers & Internet
Berenson 2 POST TISSUE HOLDER POLISHED NICKEL BER2112US14 Logo
59 people viewed this question
Top Berenson Home Experts
john h
Tom Chichester
Are you a Berenson Home Expert? Answer questions, earn points and help others
