Question about Microsoft Windows XP Home Edition
How to remove old battery? - Microsoft Windows XP Home Edition
  • alinek203 Jul 24, 2010
    thanks bill
    a friend told me about my problem being needing a new battery. others said to buy a new mouse--that mice don,t have batteries. when i purchase a new i,ll ask the salesman. thanks for your trouble.
    aline
  • 79 Answers
Hi If its the motherboard battery you want to remove, go to www.computeractive.co.uk and in page 11 of step by step video guides, you will find avideo to show you how to remove and replace the battery.Hope this helps you.
Regards Bill
Posted on Jul 22, 2010
How to change the battery?
Check polarity of old battery first.
Write this down.
Remove old battery.
Take old battery in to shop that sells new batteries.
Take new battery home.
Remove from packaging.
Refer to note you made of polarity.
Install new battery.
If it works, dump old battery.
Dec 12, 2017 | The Computers & Internet
How do i change the battery in the weber E310
Debbie, to remove the old battery, unscrew the push button cap on the ignitor and you will see the battery inside the holder. Take note of which way the old battery is facing before removing it. As that's the direction you want to install the new battery. Once you remove the old battery, check the holder for any corrosion on the battery contacts. If you see any, cleaning it off using a Q-Tip and some WD40 will do the job.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Weber Genesis E-310 Gas Grill
Batteries don't charge anymore.where do I find anew battery pack, and how do I install it?
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 28, 2011 | Philips Philishave HQ7782 Electric Shaver
Batterys loose charge quickly
Your battery pack is worn out. You will find the correct battery type at shaveroutlet.com. See link below
Mar 12, 2011 | Norelco 7737X Electric Shaver
After fully charging the battery the charge fails after 10 -15 mins of use. How can I solve this issue? Thanks Tony
the battery is dead and needs replaced. You will find the correct battery type at shaveroutlet.com. See link below
Feb 21, 2011 | Philips Philishave HQ7780 Electric Shaver
PROBLEM: WILL NOT TAKE A CHARGE. DEAD BATTERIES (?) - WOULD APPRECIATE PROCEEDURE NEEDED TO REPLACE BATTERY(S) FOR NORELCO ELECTRIC SHAVER MODEL 5821XL. SHAVER IS SEVERAL+ YRS. OLD AND IN EXCELLENT...
Dead batteries will cause the shaver not to charge. Batteries for model 5821XL can be found at shaveroutlet.com. See link below
To change, remove two screws on back and remove back cover. Remove plastic clip that is in the way of removing batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 31, 2010 | Norelco Reflex 5821 XL Electric Shaver
Not charging
Dead batteries will cause the shaver not to charge. Batteries can be found at shaveroutlet.com. See link below
Dec 27, 2010 | Norelco 5601 X Electric Shaver
Rechargeable batterys need replacing
You will find the compatible replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Remove back of shaver by taking out 2 screws on the back near the bottom. With back removed, you can access battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 01, 2010 | Philips Philishave HQ5812 Electric Shaver
Batteries dead how do you replace them?
For model 5865XL, you will find batteries for your shaver at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you first need to remove the back cover by removing the two screws on the back. One of theese screws is accessed by pushing up the trimmer. Once back is removed, you need to remove the two white plastic support pieces to properly access the batteries. You can lift out the circuit board and unsolder the old batteries but it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If this is not something you can do yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Aug 22, 2010 | Norelco 5865 XL Electric Shaver
How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Feb 12, 2010 | Philips 7110X Electric Shaver
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
