Question about Kenmore Dryers
MODEL 417.88042700. DRYER AFTER TURN ON WORKS FOR 20-30 SECS. AND GOES TO OFF WITH START BOTTON BLINKING AND INTERMITENT SOUND
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be with the thermostat/thermal fuse of your dryer however, as you said it starts for 20-30 seconds and then shuts down & also there is an intermittent sound so the issue seems more likely to be the control panel that has gone bad and should be replaced. If it was the thermostat the dryer won’t even turn on. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 21, 2010
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
Question: Our Kenmore elite microwave model 66561689101 intermitting on and off. Most of the time it turns off just after it starts and then makes a weird screech sound and then starts back up and is good...
Only thing mechanical on nuker is the cooling fan assembly and /or the turntable platter. Something not turning properly is responsible for screeching noise. And if something is not turning properly there could be a sensor to detect this and shut unit down.
Nov 21, 2013 | Dryers
Kenmore elite washer troubleshooting
The most common cause of this is the switch that tells when the door is closed. Please post the make and model
May 22, 2013 | Sears Roebuck And Co Kenmore Drain Hose...
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
I have a playsonic Tv and cant get my universal remote to work with it
first of all; is your tv model applied in the program of the universal remote? NO??? look for one that is.
yes..... but you did try all the codes and still not working?
try this with tv on:
- press and hold tv botton on remote for 3 sec until the red led light up
- then with a constant rate of each sec press off/on botton on remote. make sure to aim the remote at the set.
- at the moment the set goes off press enter. this should do the trick. NO GARANTEE....
succes and enjoy :)
Aug 23, 2010 | Televison & Video
WHIRLPOOL DUET GAS DRYER CONTROL LOCKED ON.
Hold down the end of cycle signal botton for three to five sec that should turn that off good luck
Apr 11, 2009 | Dryers
Start up
my start botton goes on for 5 seceond than blinks again but no picture
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony FAQ Troubleshooter does not help enough
You have a power supply short. Are the tubes lit in back of set? If so you have filament and no high voltage. This could because a Horizontal output, or Vertical output bad. Will need someone who knows about soldering and unsoldering.
Sep 13, 2007 | Sony KV-32FX60 TV
Dryers Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
