Question about Sony Little Big Planet
When i first start the game 2 sackboys pop up. its all fine until i get to the end of the first round and it asks that all sackboys need to stand on the platform. I cant get the other one on the platform and it doesnt let me assign controllers in the menu. What do i do?
  • 170 Answers
Make sure you don't have another controller turned on while playing unless you want to play with a friend.
Posted on Mar 03, 2011
    Problem Solver:
  • 5 Answers
Make sure you are playing with controller 1, restart your ps3 and make sure the controller is on the red light that says number 1. Or you can hold the ps3 home button down in the centre of the controller untill a menu appears, then scroll down to controller settings and then choose which controller number you would like it to be under.
Hope this helps!
Posted on Jul 22, 2010
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
Speeds don't increase after 6
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 03, 2011 | KitchenAid K45SS Classic Stand Mixer
My sackboy does not appear anymore in LBP2
http://www.littlebigland.com/lbp-2-patch-1-01-is-now-live/ Try patching the game if you haven't already. Sound's like it's a glitch.
Jun 05, 2011 | Sony Little Big Planet 2
My sackboy (player 1) can't enter on any levels on game and on line. Player 2 can, how I open them for player 1?
hmm, try re installing the game on the XMB. You DON'T have to delete your save data from the game, just re install it
May 29, 2011 | Sony Little Big Planet
Every time I start the game it pops another blank sackboy out that doesn't move and tells me to pick a profile on controller #7. I only have the 1 controller hooked up and there are no other controllers...
You probably have controllers plugged directly into your PS3 that you have forgotten about, like ones for the wireless controllers used with the various guitar and band games. Unplug those, and your mysterious extra sackboy will disappear.
Nov 07, 2009 | Sony Little Big Planet
I have a 2003 mitsubishi galant with 2.4 ltr engine. it had a loud popping noise coming from timing cover. started it back up a few diff. times trying 2 pinpoint problem. last time i started it, it started...
Uh oh Clunks are a real bad sound. Valves hitting pistons etc Check crankshaft turns by handand check valve gear rockers etc. To push in tensioner put it in a vise and SLOWLY wind in There is a small hole near piston end of tensioner that you have to line up with piston and put a small allen key or nail through to retain piston untill you refit it With belt in place only then remove pin
Oct 22, 2009 | 2003 Mitsubishi Galant
Certain PS2 games work but tohers dont
the game is not the orginal it has a copy write protect on it..you need a older version of the ps2 to play those games.it will load fine but the game pixels are different had the same problem..stay away from second hand games if you want to play cheap or older versions try gamefly
Apr 26, 2009 | Sony PlayStation 2 Slimline Console
Bust-A-Move 2 Arcade Edition Video N64 Problem
Maybe you r cleaning it to much you should stop this and check out if the conectors that go to the tv r maybe damaged or something you should check out wats the problem.
Jan 01, 2009 | Acclaim Bust A Move 2 for Nintendo 64
Sony Little Big Planet Logo
126 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
