I have bought a 4 in 1 photocopier and wish to use the equipment to receive faxes whilst conected to the computer modem and telephone service. My fax is not connecting. Please assist Model x5495
  • 112 Answers
You need to plug the copier direct to the telephone jack.
The copier will not receive any faxes as the modem on the PC is intercepting them.
If you need the PC on-line via the modem then you will need to swap out when you want to receive faxes.(or get a second line for the faxing)
If you do not use the modem on the PC for anything then leave the cable plugged into the copier.
It should automatically receive your faxes.
There will be an option somewhere for you to be able to print the fax directly or to transfer to the PC to view therefore saving paper and allowing you to make changes and fax back.
Hope this is helpful.
Please let me know if you get it to work
zod.
Posted on Apr 23, 2008
Cannot receive a FAX but can send FAX on a HP Photosmart C7180 All-in-One
are you using the same line for fax and phone???
are you using a Telephone Answeing machine or a Voice Mail??
However you can follow the following steps
1. Press the power button to turn off the HP fax product.
2. Wait for 20 seconds, and then press the power button to turn on the HP fax product, and then connect one end of a two-wire telephone cord to the telephone jack and the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Make sure that there is plain white paper in the input tray.
4. Press the Setup button on the product Control Panel.
5. Press the down arrow to select Tools, and then press OK.
6. On the Tools menu, press the down arrow to select "Run Fax Test", and then press OK. The Fax diagnostic test prints.
7. Review the report.
If the test lists faxing issues and solutions, the fax test failed.
Try the steps on the printout to troubleshoot the issue as the report is specific to your product and faxing environment.
Repeat the fax test after fixing the listed faxing issues to make sure the test passes. Try to receive a fax.
Okay, next, we need to make sure that the Auto Answer feature is turned on by following the steps below:
When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls.
1. Press the Setup button on the product Control Panel.
2. Press the down arrow to select Basic Fax Setup, and then press OK.
3. On the Basic Fax Setup menu, press the down arrow to select Auto Answer, and then press OK.
4. Press the down arrow to select On, and then press OK.
5. Try to receive a fax.
Since the issue persists, the problem could be due to some conflicting telephone services.
The following telephone company services might block or interfere with incoming faxes:
Distinctive Ring Service: A distinctive ring service, if it is available from the telephone service provider, often resolves this issue.
* Voice mail: It is possible to use the fax in manual receive mode while using a voice mail service. For manual receive mode, turn off auto answer and press "Start Fax Black" or "Start Fax Color" on the control panel before the voice mail picks up the line to start receiving the fax.
* Call waiting: Do not use a call waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
* Privacy block
* Security screen
* Anonymous call rejection
* Privacy manager
* Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to the HP fax product, contact the telephone service provider for its recommended solution.
After addressing any existing conflicting telephone services, try to receive a fax.
Try contacting telephone people
try changing the settings below
2. Press the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Fax Speed, and then press OK.
4. Use the down arrow to select Medium, and then press OK.
5. Try to receive a fax again. If the HP fax still cannot receive a fax, try lowering the fax speed even further
Next, change the "Rings to Answer" setting on the HP fax by following the steps below:
2. Press the right arrow key to select Basic Fax Setup, and then press the OK button.
3. Press the down arrow to select Rings to Answer, and then press OK.
4. Use down arrow to select the desired number of rings, and then press OK. you cn change the rings to answer to 6 if your telephone answering machine picks up the call after 4 rings.
If the HP fax still cannot receive a fax, change the following steps
2. Use the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Error Correction Mode, and then press OK.
4. Use the down arrow key to select Off, and then press OK.
1. Plug the telephone cord directly into the telephone jack and not through any other device.
2. If present, remove any splitters or other devices attached to the line, except for a DSL filter.
3. If the telephone cord is over 3 m (10 ft) long, move the fax closer to the telephone jack, and then use a cord 3 m (10 ft) long or shorter.
4. Connect the other end of the telephone cord directly to the back of the HP fax product into the port labeled 1-Line.
5. If other devices such as, telephone answering machines or computer modems, are attached to the telephone line, remove them. If devices attached to other extensions of the same telephone line are present, remove them for this test.
6. Try to receive a fax.
If removing telephone devices and connections allows the HP fax product to receive faxes, this indicates interference from one or more of the removed devices. Interference can be caused by incompatibility or by using too many other telephone devices at once. Telephone devices can be added back but test after adding each to make sure that they do not start to interfere again.
If the HP fax product still cannot receive a fax after removing other devices, continue with the following steps:
7. If a DSL filter is needed on the telephone line, change the DSL filter and then try to receive a fax. If the HP fax product still cannot receive a fax, proceed to step 8.
8. If a new telephone cord has not been tried, change the telephone cord to a new two-wire telephone cord, and then try to receive a fax again.
if it does not resolve then perform the following steps
1. Disconnect the power cord from the back of the product.
2. Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel.
3. Connect the power cord to the back of the product and then release the buttons when the product turns on.
4. The product resets to factory defaults.
As a last step, test in another location by following the steps below:
If possible, move the HP fax product to another location with a separate telephone line (another house for instance).
Try to receive a fax at that location, and if you are able to receive faxes from the changed location, then your telephone line should be tested.
If it resolves well and good if it does not then service the printer
Dec 12, 2012 | HP Photosmart C7180 All-In-One InkJet...
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
I can send faxes but cannot receive them fax test tells me there is no dial tone detection
* Privacy block
* Security screen
* Privacy manager
Oct 28, 2012 | HP Photosmart C7180 All-In-One InkJet...
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
Oct 25, 2010 | AT&T High Speed DSL Modem
Dell printer A940 fax trouble
Unless you have 'VOIP' telephone service with Comcast, your FAX will connect through your home's telephone line, not the internet (or modem). You would connect your phone line to the all-in-one printer, then follow Dell's instructions for use. Good luck!
Apr 18, 2009 | Dell A940 All-In-One InkJet Printer
I am not receiving fax\. When trying 2 snd fax it says follow me is accessed.
Try to switch off the equipement, wait for ten seconds and switch it on again, so a reset is done. Also check for a telephone line as if it is ok by conecting a normal telephone to the fax line. GOOG LUCK.
Nov 20, 2008 | Canon FAX-L380 Plain Paper Laser
How can I install my fax HP640
All fax machines are ANALOG devices. They are designed to work on POTS (Plain Old Telephone System). Any other condition is a **** shoot.
Jul 21, 2008 | HP 640 Inkjet Fax Machine
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
57 people viewed this question
jasbo
jasbo
